1. bassplayrguy's Avatar
    So I uninstalled Nova and went back to TW and now my wallpaper doesn't move when I move my phone. This happened before and I stumbled across the setting for this but I cannot find it now. Anyone run into this and know where to find the setting? Thanks in advance.
    07-17-2017 09:15 AM
  2. Javier P's Avatar
    Maybe something got stuck after using a custom launcher. Just in case go settings - apps - default apps and make sure that TW is checked for 'home screen'.
    07-17-2017 09:20 AM
  3. thoughtjunky's Avatar
    If you go to set your wallpaper again, you should see a check box for the wallpaper motion effect under the preview.
    07-17-2017 09:20 AM
  4. bassplayrguy's Avatar
    There is a setting you have to change in order for that option to become available.
    07-17-2017 09:38 AM
  5. bassplayrguy's Avatar
    Found it!!! When you uninstall another launcher, to get this back, you have to go into Settings, Apps, 3 dots at top for defaults, Homescreen, and make sure the circle has a dot in it for TW home.
    Javier P likes this.
    07-17-2017 09:42 AM
  6. Javier P's Avatar
    Glad you found it! Did you miss my post half an hour ago? haha
    07-17-2017 09:48 AM
  7. bassplayrguy's Avatar
    Well hell I am blind. 😂
    07-17-2017 09:50 AM
  8. bassplayrguy's Avatar
    Wow do I feel dumb. I didn't see that. Would have saved me a half hour of looking.
    07-17-2017 09:51 AM
  9. Javier P's Avatar
    Wow I feel dumb. I did miss that. I'm sorry.
    No worries, mate! I was just kidding. I don't know exactly why, but it seems that option needs to be selected again every time you switch launchers. Glad you managed to get it fixed!
    07-17-2017 09:52 AM
  1. Distorted color and picture when using boomerang app... help
    Last Post: 09-14-2018, 11:09 AM
  2. New S7 Owner...Please Help
    By charlesxy in forum Samsung Galaxy S7
    Last Post: 07-17-2017, 10:30 PM
  3. Need help to turn off screen overlay
    Last Post: 07-16-2017, 02:43 PM
  4. Help how do I get rid of keyboard pop ups?
    Last Post: 07-16-2017, 12:41 PM
  5. Hacked or Mirrored Phones and Tablets PLEASE HELP!
    By Ellz7 in forum Android 7.0 Nougat
    Last Post: 07-16-2017, 08:07 AM
