1. brmmst's Avatar
    Like if you have to take phone with you when temperatures outside are very high or low. I know those temps can be very bad for battery or phone itself. What do y'all do to keep it protected? There's a case out there called Salt Cases which is supposed to be thermal protection for phones. Anyone try this? Thanks!
    Morty2264 likes this.
    07-20-2017 02:04 PM
  2. anon(238680)'s Avatar
    Keeping it out of direct sunlight would be necessary. Holding it near your body would work with cold. It it was hot enough outside to harm the phone I would be much more concerned about myself. A case like that might be necessary in the Sahara, but its expensive.
    Morty2264, Qc_Anubis and Alan Sims like this.
    07-20-2017 02:12 PM
  3. Morty2264's Avatar
    If it's raining, I'll sometimes wrap my phone up in one of my socks and put it in the middle of my purse to keep it protected in case of any water coming through my bag. If it's direct sunlight, I never keep it out where the sun will bake it. And when it's super cold, I usually keep it in my purse and don't use it outside unless it's absolutely necessary. So basically, to summarize, my purse is my protector. :P
    anon(238680) likes this.
    07-20-2017 02:14 PM
  4. ruggedhunter's Avatar
    When driving, my phone is mounted on the windshield in direct hot summer sunlight... running navigation with bright screen, discretely recording video (no sound) and constantly listening for my custom voice commands (no ok Google keyword needed).... overclocked slightly and no undervolt... so without heat protection my device will overheat quickly. I run the air conditioner and blow it out the dehumidifier vents so it hits my windshield mounted s8+. That works nicely. If my car didn't have a/c then I wouldn't able to use my phone like that.
    When hunting in extreme cold temperatures for 14 hours a day in December and January I need to keep my phone in a pocket close to my body and/or with a chemical handwarmer. Otherwise my battery drains even if off.
    07-20-2017 05:25 PM
  5. Doug Moffat's Avatar
    I've been consistently touting the leather Samsung folio/wallet. I'm speculating but I suspect it provides better than average protection against temperature extremes.
    07-20-2017 09:37 PM
  6. anon(7901790)'s Avatar
    You're more likely to run into over heating than freezing. However, the phone has a warning and an auto shutdown if it gets too hot. If you're charging it and it starts getting hot, the phone will warn you and stop charging.
    Cold weather is less of a problem. Unless you're going to be in below freezing environments for extended periods of time without any way to keep warm, it should be fine. I'd bet that you would be seeking shelter before the phone would stop working.
    07-21-2017 01:44 AM
  7. skipatrol's Avatar
    I usually take my phones skiing with me. I like to use a pouch with the phone kept inside my jacket next to my chest. Battery temp usually drops to 50 or so. Never really had an issue. On really cold days (or nights) I power the phone off.
    07-21-2017 06:44 AM
  8. Tim1954's Avatar
    If you can survive it, so can your phone.
    07-21-2017 06:45 AM
  9. trucksmoveamerica#AC's Avatar
    What about using phone Mount vent clips, where you would have cold AC air blowing on the back, you think that would be an issue with temp or moisture forming on it?
    07-21-2017 07:43 AM
  10. uncaged74's Avatar
    The phone itself is in an Otterbox, and then in it's in a leather case/pouch thing. I keep that on me and no issues. It's when I left them in the car is where I found issues.
    07-21-2017 08:56 AM
  11. anon(7901790)'s Avatar
    I actually do that. It gets too hot in the window mount because of direct sunlight. So far no problems. Most car A/Cs don't get colder than 65 F.
    07-22-2017 01:42 AM
  12. Doug Moffat's Avatar
    Good test.
    Tim1954 and Morty2264 like this.
    07-22-2017 10:18 AM
  13. Qc_Anubis's Avatar
    Year round protector = my pockets wether it's -40 celcius or +40 (i'm in canada so convert this if you want to), never had a single issue with any phone. A heat case reminds me of a "bend proof" case i saw for the iphone 6 back when they had the so called "bendgate" it's just a pr stunt nothing more, if the temp is harsh enough for your phone be concerned about yourself first lol.
    07-22-2017 10:30 AM
  14. Gayle Lynn's Avatar
    Can you shield it with reflector foil so it only gives shade to phone without blocking your view?
    07-22-2017 11:49 AM
  1. Replies: 7
    Last Post: 07-20-2017, 05:48 PM
  2. Links opening in apps without asking first
    By Pentagen in forum General Help and How To
    Last Post: 07-20-2017, 04:07 PM
  3. Do Not Disturb keeps turning itself off
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 07-20-2017, 03:39 PM
  4. How can I stop long sms being converted to mms on uk s7
    Last Post: 07-20-2017, 01:47 PM
