1. koda123456's Avatar
    I recently purchased a S8+ and the battery backup is horrible. Please check the SS i am attaching and tell me whether the battery drain is normal? The screen resolution is set at FHD+ with AOD off still with just 1.3hrs of SOT. Please help me out. BTW i am using global exynos model.
    Attached Thumbnails Is this normal (my S8+ Battery Life)?-screenshot_20170803-000305.jpg   Is this normal (my S8+ Battery Life)?-screenshot_20170803-000313.jpg
    08-02-2017 01:42 PM
  2. Tim1954's Avatar
    Nearly 8 hours and you have 40% left.. Looks good to me.
    There are huge range of variables, how strong is your cell signal, what apps are running, how often they synch....
    beandaddy likes this.
    08-03-2017 01:54 AM
  3. koda123456's Avatar
    I didnt use the phone that much, maybe now and then to check notifications thats all. With just 1.3hrs of screen on time and standby the battery has drained so much. No apps were running in the background. People are getting 4hrs+ of SOT and the battery just drains down to 50-60%. Thats why I am worried if theres something wrong with my phone.
    08-03-2017 02:04 AM
  1. Fast wireless charger stand for an s8+ with otterbox defender case
    By AC Question in forum Samsung Galaxy S8 & S8+ Cases & Accessories
    Last Post: 08-02-2017, 03:33 PM
  2. POP UP ads from Hell on Galaxy S8
    Last Post: 08-02-2017, 02:42 PM
  3. Why is my android zte needs to sign in with google account?
    Last Post: 08-02-2017, 02:36 PM
  4. Why does my Moto 3 always shut off
    Last Post: 08-02-2017, 02:35 PM
  5. Google Services drains data and battery for past 3 days
    By Faizal Firdaus in forum Android 5.0 Lollipop
    Last Post: 08-02-2017, 01:22 PM
