1. smeg36's Avatar
    I switched to Sprint recently for the year of free service, but they aren't the best with LTE data speeds in Miami. A lot of places 3G is actually faster than LTE, including my house.
    Is there an easy way to toggle between 3G and LTE? The only way I found was to change the Network mode to CDMA. But that requires a reboot both to switch to 3G, and back to LTE. On the iPhone there's a toggle switch to turn LTE on or off. Something like that in settings would be really nice. Something in the notification shade would be even nicer.
    08-02-2017 03:34 PM
  2. MobGeek's Avatar
    What are the other options under the device network settings?
    08-02-2017 04:02 PM
  3. smeg36's Avatar
    I've attached screen shots of the settings I have under the Mobile Network settings. Changing any of the Network mode settings requires a reboot. I did try a few apps from the Play store that worked to switch to 3G without a reboot, but none of them were very polished.
    Attached Thumbnails Toggle between 3G and LTE without rebooting-screenshot_20170802-172838.jpg   Toggle between 3G and LTE without rebooting-screenshot_20170802-172928.jpg
    08-02-2017 04:34 PM
  4. MobGeek's Avatar
    Based on the image, network settings is on Automatic that case your network connection will switch automatically from LTE and 3G automatically. From what I've checked, in order to change network connection for Sprint devices, a reboot is needed to take effect.
    However, you can try this simply trick for your phone:
    Text instructions :
    1. Enter *#0011#
    2. Menu (Top right button) -> Key Input -> Type "Q" and press "OK"
    3. Again go to Key Input -> Type "0000" and press "OK" and WAIT 10 Seconds
    4. If you get a "0" response. Restart from Step 1, then it will work.
    5. If the system is OK you will see "Main Menu"
    6. Select Option [2] UE SETTING & INFO
    7. Then Option [1] SETTING
    8. Then Option [1] PROTOCOL
    9. Then Option [2] NAS
    10. Then Option [1] NETWORK CONTROL
    11. Then Option [4] BAND SELECTION - Note if you are Duo's then select SIM1 or SIM2
    12. Then Option [4] LTE Band Preference - NOTE Set [8] Automatic to disable LTE Only mode.
    13. Then Option [8] LTE ALL
    From there, you'll have an option to select your network without rebooting the device.
    PS: I haven't tried it using Samsung S8 but this simple codes work on most Samsung series phones.
    Let me know on any results.
    08-02-2017 05:03 PM
  5. smeg36's Avatar
    Wow, that's pretty complicated. I've found some apps that can do it easier than that, and without rebooting, but I'd love to have a button in the quick settings notification shade.
    08-02-2017 07:12 PM
  1. Has Anyone Here Used Both the G6 and U11?
    By Morty2264 in forum LG G6
    Last Post: 08-09-2017, 11:46 AM
  2. tough to choose between carrier version or unlocked
    By AKFL3TCH3R in forum Samsung Galaxy S7 edge
    Last Post: 08-02-2017, 06:36 PM
  3. VLC app and OTG music on usb stick
    By stevewoodrow11 in forum Android Apps
    Last Post: 08-02-2017, 02:18 PM
  4. Replies: 3
    Last Post: 08-02-2017, 01:26 PM
  5. Google Services drains data and battery for past 3 days
    By Faizal Firdaus in forum Android 5.0 Lollipop
    Last Post: 08-02-2017, 01:22 PM
