1. AC Question's Avatar
    It's especially noticeable on a screen that's a solid color like blue. Towards the top of the screen (the selfie camera end) the shade of blue will be noticeable brighter than the shade of blue towards the bottom of the screen.
    It's no huge deal, a bit disappointing, but if it's not how it should be I have time to exchange it.
    08-04-2017 10:07 PM
  2. Tim1954's Avatar
    Dial *#0*# to test the hardware
    08-04-2017 10:37 PM
  3. coolie_375_X's Avatar
    I'm having the same problem, I have tested the software using *#0*# and I haven't got any useful info, what's happening?
    02-12-2018 06:31 AM
  4. TFBisquit's Avatar
    It's not normal no. Should be evenly bright.
    mary beth hale likes this.
    02-12-2018 10:30 AM
  5. mary beth hale's Avatar
    Sounds like a hardware issue. Are you still under warranty?
    02-12-2018 01:03 PM
  1. why is my tablet switching itself off?
    Last Post: 08-05-2017, 09:52 PM
  2. What is launcher4? My RealPad no longer works. Can I fix it.
    Last Post: 08-05-2017, 09:51 PM
  3. Why wont my Galaxy s5 acknowledge ive put an sd card ini
    By S m Kelly67 in forum Android 6.0 Marshmallow
    Last Post: 08-04-2017, 09:37 PM
  4. Replies: 1
    Last Post: 08-04-2017, 09:34 PM
  5. Samsung galaxy s7 1440p resolution lag
    By deadpixel188 in forum Samsung Galaxy S7
    Last Post: 08-04-2017, 08:14 PM
