1. Bajrami's Avatar
    Why is my battery draining without using it i sleep with 90% and i woke up with 0% ps it my new galaxy please help??
    08-10-2017 09:02 PM
  2. Kawinj's Avatar
    Did you update recently? Sometimes updates are fine, other times they cause problems.
    08-10-2017 09:14 PM
  3. Bajrami's Avatar
    @Kawinj yes what can i do to fix this problem,is it normal?
    08-10-2017 09:32 PM
  4. BrockS.'s Avatar
    Back up your device to Samsung Cloud, Smart Switch, or your provider of choice, then do a factory reset if this occurred after the update.
    To my knowledge, and I admit I am no expert, this should not damage your battery.
    H3aTeRzz likes this.
    08-10-2017 10:03 PM
  5. B. Diddy's Avatar
    Welcome to Android Central! It would help to see some battery stats, since there are many reasons why battery might be draining (like a rogue app, or poor cell signal). Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    08-11-2017 02:31 AM
  6. dizzle16's Avatar
    Same thing happened to me yesterday. But it was Android system
    Attached Thumbnails samsung galaxy battery drains without using it?-6042.jpg
    08-11-2017 07:26 AM
  7. Bajrami's Avatar
    thank you all ,my battery is okay now
    08-11-2017 08:36 AM
  8. Klbg's Avatar
    Same thing is happening to me this week with my Moto Z play. I used to be able to go several days between charges and now I have to charge it every night. Is there an easier way to find which update is causing it? Does a factory reset erase everything? Such a bummer because now I don't want to update anything anymore.
    08-11-2017 08:39 AM
  9. B. Diddy's Avatar
    Is there a reason why you think it was an update that caused this? It could be other things, like a rogue app or poor cell signal. Seeing the screenshots I suggested previously would be helpful. You could also try wiping the cache partition: https://motorola-global-portal.custh...p/30,6720,9835
    08-11-2017 10:58 AM
  10. mia_xoxo's Avatar
    I have the same issue. Not sure what it could be since its been like this since day 1. I've just excepted that this is what to expect from Samsung devices. I still carry my iPhone 7 so I'm good.
    08-11-2017 07:41 PM
  11. T48's Avatar
    See post 4 above. Something is not right. Have an S8+ & have zero issues with the battery.
    08-12-2017 12:41 AM
  12. mia_xoxo's Avatar
    So I reset the phone and OMG it is a world of a difference. My battery doesn't drain nearly as fast as it did before! Thanks for the tip.
    T48 and tube517 like this.
    08-12-2017 09:16 PM
  1. Unable to Backup Samsung Galaxy S6 Edge Plus
    By MounaLafi in forum Samsung Galaxy S6 edge+
    Last Post: 08-11-2017, 02:28 AM
  2. Replies: 2
    Last Post: 08-10-2017, 10:31 PM
  3. Fast Charging Galaxy S5
    Last Post: 08-10-2017, 08:15 PM
  4. Using refurbished charger
    Last Post: 08-10-2017, 07:54 PM
