1. AC Question's Avatar
    My new Galaxy S8 will not allow me to use data (search the internet or use apps) while talking on the phone. After calling samsung, I was told that the phone does not allow data while talking??? The Verizon representitive who was on the same call confirmed that this was not a problem caused by Verizon. The Samsung representatives were absolutely no help. Has anyone else experienced this problem?
    08-11-2017 06:14 AM
  2. VW Maverick's Avatar
    Welcome.
    That is a good question.
    We'll move this to the S8 forums to find out.
    Mav.
    08-11-2017 08:31 AM
  3. Javier P's Avatar
    Mod note. Thread moved to the S8 & S8+ forum for better visibility.
    08-11-2017 08:39 AM
  4. drewood31601's Avatar
    the old note 3 phones had 2 radios which allowed you to use data and voice at the same time . with one radio, that ability will be based on the carrier and how it handles voice and data.
    08-11-2017 09:24 AM
  5. TylerLV76's Avatar
    Is your phone a Verizon branded phone, unlocked phone from another carrier or Samsung unlocked phone?
    08-11-2017 10:22 AM
  6. Ecm's Avatar
    That sounds about right. On my S8+ (on Rogers), I frequently drive with Google maps going while on a phone call. No issues, ever.
    soc_phish likes this.
    08-11-2017 10:23 AM
  7. Ca_lvn's Avatar
    Sprint is the only network that doesn't allow data and phone usage, sorry no help with your problem
    08-11-2017 10:34 AM
  8. Almeuit's Avatar
    Well since the OP said he's on Verizon if he turns on VoLTE (Verizon calls it Advanced Calling) it won't be an issue. Example attached below as I'm on a call while I type this.
    @ OP - ensure Advanced Calling is on via your account. After that go to settings > Advanced Calling on your phone and turn on the setting.
    jbjtkbw007 likes this.
    08-11-2017 01:19 PM
  9. jbjtkbw007's Avatar
    This goes back to that old mantra: CDMA usually doesn't allow data at the same time on a call (with the recent exception of VoLTE) and GSM will allow data and voice simultaneously (as in the Rogers case above). This is one reason I switched back to GSM even the CDMA will give you better penetration into buildings.
    08-11-2017 01:58 PM
  10. andrew_ackley's Avatar
    Verizon does do simultaneous data and phone call but I think u have to be in lte coverage for something.
    08-11-2017 03:47 PM
  1. Why can't I disable my lock screen option
    Last Post: 08-11-2017, 01:28 PM
  2. Unfortunately email has stopped message on my android
    Last Post: 08-11-2017, 11:24 AM
  3. Replies: 1
    Last Post: 08-11-2017, 11:22 AM
  4. I lost my lockit app!
    Last Post: 08-11-2017, 07:23 AM
  5. I lost my lockit app!
    Last Post: 08-11-2017, 06:17 AM
