1. LoveMyPhone's Avatar
    I think it's using more battery than the other apps by telling me every few minutes that I have apps that
    are draining my battery or need to be put to sleep
    Is there any way to get rid of it or put it to sleep?!?
    08-11-2017 12:44 PM
  2. cgwillard's Avatar
    I used bk disabler.
    LoveMyPhone likes this.
    08-11-2017 12:46 PM
  3. LoveMyPhone's Avatar
    I used bk disabler.
    I'll give it a try. Thanks!
    08-12-2017 05:48 PM
  4. Lepa79's Avatar
    May be you do have app that are not optimized. Mine hardly says apps are draining my battery except for my work email app. If you want, you can disable notifications so you are not bothered by these notifications. In my opinion, it's not draining your battery
    08-12-2017 06:35 PM
  5. BratPAQ's Avatar
    I put all apps I don't need running on background to "always sleeping apps". So I don't get notifications that an app is about to be put to sleep.
    allrightallright likes this.
    08-13-2017 12:16 PM
  6. Soylent_Green's Avatar
    It's all in your head, it's fine.
    08-14-2017 03:35 PM
  7. neil74's Avatar
    Never thought to disable this one. When compared to say an LG G6 the standby drain on Samsung phones is poor and it could be one or a combination of stuff causing this. I pkg disabled my S8 heavily and never really improved standby life significantly but never tried disabling device maintenance.
    08-16-2017 08:54 AM
  1. What is. Com.sec.anroid.ap.sbrowser
    Last Post: 09-17-2018, 02:24 PM
  2. my samsung galaxy j5 is not receiving text messages. why ?
    Last Post: 04-15-2018, 11:51 AM
  3. Why does my Galaxy S7 Active have very poor battery life?
    By SomewhatOfAGuy in forum Ask a Question
    Last Post: 08-11-2017, 02:46 PM
  4. Replies: 1
    Last Post: 08-11-2017, 11:40 AM
  5. My j7 prime phone side switch is not working
    Last Post: 08-11-2017, 11:32 AM
