1. bialy's Avatar
    How is the performance etc of the Ikea wireless charger pad, Nordmarke?
    It looks more attractive looking than most pads, fwiw.
    NORDMÄRKE Single pad for wireless charging - IKEA
    08-26-2017 12:27 PM
  2. L0n3N1nja's Avatar
    Guess I can't say for certain, but it's QI Certified so it should charge the same as any other QI Certified charger.
    So safe bet it has the standard wireless charge rate and not the fast charge that Samsung supports. To my knowledge Samsung is still the only one with fast wireless charging.
    That does look better than most, I would fear some would assume it's a coaster. Lol
    08-26-2017 01:45 PM
  3. Ecm's Avatar
    I've used that charge pad at a friend's house. It works, but at the standard rate. The Samsung fast wireless chargers, or this one by Anker, all charge much more quickly. This Anker charges as quickly as the Samsungs, and takes USB-C input.
    https://www.amazon.ca/gp/product/B01...cUvbUpU5940063
    08-26-2017 02:49 PM
  1. Charging blocked by moisture, help needed.
    By Notesfromtheunderground in forum LG G6
    Last Post: 06-21-2018, 05:08 AM
  2. HDMI - Does S8 try to charge my TV?
    Last Post: 08-26-2017, 12:53 PM
  3. Replies: 2
    Last Post: 08-26-2017, 07:56 AM
  4. my samsung galaxy core prime won't charge with car charger
    Last Post: 08-25-2017, 04:37 PM
  5. Replies: 0
    Last Post: 08-25-2017, 03:10 PM
