Originally Posted by
kurpaige The question is how do you make your selections default? If I add an alarm its back to bixby briefing on and alarm tone and volume off. I have to change this every time I set an alarm. How do you change the default to being bixby briefing off and alarm tone set to what I set it to?
I have Bixby briefing turned off, so my default sound stays the same every time.
Not sure if you're asking about keeping Bixby briefing on and still retaining your chosen sound as default...? If you turn briefing off and it keeps coming back then I don't know the reason/answer. good luck.
