1. ShadowFlame's Avatar
    Is there a setting to change the duration of the edge lighting? As it only flashes for a couple seconds and then stops even with the phone face down. This is mainly regarding when a text message comes in the edge lighting flashes for a couple seconds then stops, but the Led light continues to flash which is what I thought Edge lighting was supposed to do?
    08-30-2017 10:38 AM
  2. anon(9602380)'s Avatar
    There is no duration setting for edge lighting. It is what it is. Thanks.
    08-30-2017 10:56 AM
  3. ShadowFlame's Avatar
    Well that is mildly disappointing, but thanks for the answer
    08-30-2017 03:49 PM
  4. Darth Mo's Avatar
    Yeah, the Edge lighting seems like a gimmick in its current state. What are the odds that you're actually looking at your phone for that second or two where it's flashing?
    It's a little better since the update the other day where you can make it wider. You *may* be able to catch it out if the corner of your eye now.
    Hopefully they update it to where you can set it to go off every few minutes.
    08-30-2017 05:10 PM
  5. THEPRFCT10's Avatar
    My edge lighting is spotty at best. With the 6 apps I currently have activated so far it's worked only half the time. Also my LED notification light doesn't work now. Weird.
    08-30-2017 09:35 PM
  6. Darth Mo's Avatar
    There is a slider for turning off the LED notifications, perhaps you hit it accidentally?
    09-01-2017 11:31 AM
  7. kcalmol's Avatar
    Would be nice to have edge lighting pulse for a set duration, and be able to customize by contact.
    09-01-2017 06:27 PM
  8. scamoore's Avatar
    Maybe with enough comments here, Samsung might get the clue. It's useless now with a nano flash. The edge lighting duration needs to be adjustable.
    11-28-2017 12:46 PM
  1. How do i get green light notification for texts?
    Last Post: 08-30-2017, 01:07 PM
  2. Blue LED light on my phone not flashing
    Last Post: 08-30-2017, 01:01 PM
  3. I can't delete an event on my s7 edge calendar.
    Last Post: 08-30-2017, 12:18 PM
  4. Does your LEAD notification work with the new edge lighting notification?
    By THEPRFCT10 in forum Samsung Galaxy S8 & S8+
    Last Post: 08-30-2017, 08:39 AM
  5. Why is character preview not working on my samsung s6 edge plus.
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 08-30-2017, 06:30 AM
