1. CosmicMiami's Avatar
    After searching for a couple days I finally found a solution to the all too common Gmail Contacts sync problem. Turns out, it is the power saving mode that changes everything.
    I switched to non power-saving and voila! contacts synced immediately.
    Now my question is, why would that setting not allow my contacts to sync? Seems like it should have nothing to do with sync. I know, sync uses resources but man, when I tell the machine to sync it should do it regardless of power saving settings.
    BTW, I'm on nougat.
    09-04-2017 09:20 AM
  2. PJRed2008's Avatar
    Thanks for posting your solution! No reason other than syncing uses battery power. You can also turn that off selectively for individual apps in battery settings.
    CosmicMiami likes this.
    09-04-2017 10:28 AM
  3. hydrofarmer's Avatar
    Mine still does it randomly with power save off
    09-04-2017 06:18 PM
  4. hydrofarmer's Avatar
    I said screw it and downloaded bluemail. I missed two very important emails this morning. One was sent at 845 and and the other at 1015am. I didn't get notified until after 3 pm. All power saving off. I made sure Gmail wasn't on the list to sleep. This is retarded.... Hopefully bluemail solves the problem. Also I noticed Gmail wasn't on the list to be able to bypass power save mode on my phone. Actually I couldn't find Gmail anywhere in the battery / powersavig menu.
    09-05-2017 05:27 PM
  1. Galaxy note 4 has an mmc problem, how long will it live?
    By Tim Akgayev in forum Samsung Galaxy Note 4
    Last Post: 09-13-2018, 10:02 AM
  2. Verizon Galaxy S8 Gmail quit syncing while on Wifi
    By dorlisa in forum Samsung Galaxy S8 & S8+
    Last Post: 09-12-2017, 10:50 PM
  3. Galaxy A5 2017 screen yellowing problem
    By kyry1 in forum Samsung Galaxy A5
    Last Post: 09-07-2017, 03:43 PM
  4. need help with root problem??
    By hawking45 in forum Ask a Question
    Last Post: 09-05-2017, 12:08 PM
  5. How to fix Audio video sync problem?
    By Christine Ombing in forum General Help and How To
    Last Post: 09-04-2017, 03:36 PM
