1. justdubya's Avatar
    Don't get me wrong this is a great phone but I'm noticing some issues lately. These may be a bit trivial but they're annoying. Hoping someone here can help.
    Within the last month or so Google Allo notifications have become a mess. Everything from notification sounds and vibration getting cut short to not getting notifications at all. This is the only app to have this problem. I did a factory reset and the issue persists.
    Also, the latest update of youtube has messed up my crop-to-fit fullscreen mode. The video will stretch up but not out to the sides creating a stretched tall video.
    Is anyone else experiencing things like this lately? Any help is appreciated.
    09-05-2017 08:46 AM
  2. Axidrain's Avatar
    Have u tried a hard reset
    09-05-2017 08:48 AM
  3. justdubya's Avatar
    I uninstalled and reinstalled everything, did a (hard) factory reset, a soft (wipe cache partition) reset, and booted into safe mode to see if things were any different. Nothing changed the problems.
    For the moment I have the Factory version of youtube on here that came with my phone and the crop to fit works with that version for whatever reason. So I kind of fixed it... but I can't update youtube.
    09-05-2017 08:57 AM
  4. hckyjoc's Avatar
    I've started experiencing the same issue with Allo. My current work around is to have the repeat notification setting turned on. Please let me know if you find an actual solution.
    09-06-2017 12:01 AM
  5. bassplayrguy's Avatar
    Uninstall update on YouTube to fix that problem
    09-06-2017 08:32 AM
  6. justdubya's Avatar
    I hadn't thought of that. I'm going to turn that on. I'm still looking for fixes. If I find anything I'll report back here. Thanks!
    09-06-2017 09:54 AM
  1. S8 Google Assistant problem
    By malenki22 in forum Samsung Galaxy S8 & S8+
    Last Post: 09-06-2017, 09:43 AM
  2. Replies: 2
    Last Post: 09-06-2017, 07:23 AM
  3. Replies: 31
    Last Post: 09-05-2017, 10:50 AM
  4. What does the icon key mean on your Android LG phone
    By John Noffsinger in forum Ask a Question
    Last Post: 09-05-2017, 10:17 AM
  5. Connecting to an existing Vpn Server With IPSEC
    By ahmedespritien in forum Android 5.0 Lollipop
    Last Post: 09-05-2017, 03:43 AM
