1. uncaged74's Avatar
    A few days ago I learned how you can use that USB-C to USB adapter which I am currently using to type this from an actual keyboard and mouse (not Bluetooth mind you) but using the USB adapter for the peripherals into the adapter and boom you basically have a computer. The thing is, by design of the adapter and my case, the adapter doesn't fit unless I take it out of the case. So what I am looking for is the adapter concept but more of a cable design about 6 inches in length at most. I Google and yet to find what I am looking for.
    In case you are not sure what I am speaking of, here is the video.
    09-07-2017 09:48 PM
  2. SpookDroid's Avatar
    Not sure if they exist or not (since the adapter comes in the box I haven't searched for one in ages). Samsung used to sell these for micro-USB before they started including the adapter in the box for device transfer. You're looking for OTG USB-C cables. If they exist, that's how they'd come up in your search at your favorite store.
    09-07-2017 10:25 PM
  3. uncaged74's Avatar
    thanks. I will Google it later on.
    09-08-2017 10:48 AM
  4. tuscanybay's Avatar
    I believe what you are looking is available in eBay. Search for "USB-C Type C Male to USB 3.0 Female OTG"
    09-09-2017 06:22 PM
  5. SpookDroid's Avatar
    Just make sure the keyword OTG is present. Otherwise you're just getting an extension cable.
    uncaged74 likes this.
    09-09-2017 10:10 PM
  6. badcat's Avatar
    I got one of these from Amazon. I'll see if I can get the model number for you.
    The Amazon app won't let me copy text so I'll just write it out.
    LighningKid USB C to USB 3.0 OTG cable. It was only $8.00 and worked great. I've used it with a Nexus 5X and my S8.
    09-10-2017 05:30 AM
  7. uncaged74's Avatar
    @SpookDroid & @badcat
    Thanks guys!
    badcat likes this.
    09-13-2017 09:43 AM
  8. uncaged74's Avatar
    I ordered these:
    Nekteck USB-IF Certified(2-PACK) USB C TO USB 3.0 Adapter USB 3.1 (Gen1) Type C Male to USB3.0 A Female Cable Connector Support OTG Function, For Macbook Pro Samsung Galaxy Note 8 etc 0.15M/BLACK
    09-13-2017 10:53 AM
  9. badcat's Avatar
    Those look pretty good. Let us know how they work out.
    09-13-2017 11:59 AM
  10. uncaged74's Avatar
    Will do. My next thing will probably be a dual-adapter where we can utilize OTC and charge the phone at the same time.
    badcat likes this.
    09-13-2017 12:10 PM
  1. Baby Steps to End my Addiction...cancelled my Note 8 preorder.
    By bembol in forum General News & Discussion
    Last Post: 09-20-2017, 05:27 AM
  2. Some Games Doesn't Go Online Now, How To Fix It !!?
    By Mohamed MAK in forum Samsung Galaxy S7 edge
    Last Post: 09-10-2017, 12:02 AM
  3. How to get a note 8 with 128 or 256 gig of memory
    By h2ofun in forum Samsung Galaxy Note 8
    Last Post: 09-09-2017, 06:25 AM
  4. Voice to text question/ screen sensitivity
    By BeyondMeasure in forum Samsung Galaxy Note 8
    Last Post: 09-07-2017, 07:41 PM
  5. Replies: 0
    Last Post: 09-07-2017, 07:02 PM
