1. Esh12305449's Avatar
    Hello all, this galuxy 8+ is my 1st smartphone and i love it. But I need help. The 1st issue I have is rhis; I just bought a set of beats wireless headphones they sound ok, a little better than factory. Is their a way to increase the Volume? If so pls help, but remember I'm a newbie.
    Appreciate all help.
    09-10-2017 08:00 AM
  2. BratPAQ's Avatar
    Turn on adapt sound preset 3.
    sweetypie31 likes this.
    09-10-2017 09:16 AM
  3. munnarg's Avatar
    Some headphones have their own volume independent of the phone's volume. Try raising your phone's volume to max, then see if using the volume controls on the headphones still increases the volume.
    09-10-2017 01:53 PM
  4. CincyGuy's Avatar
    If the adapt sound preset recommendation doesn't work, you can try Precise Volume (free version, but there is a paid pro) which hass all kinds of presets you can set that actuvate automatically when different types devices are connected via bluetooth.
    https://forums.androidcentral.com/e?...token=rse1FjET
    09-10-2017 02:54 PM
  1. Can i turn vibrate off on my Huawei Nova alarm?
    By Simric in forum Huawei P9 & P9 Plus
    Last Post: 09-13-2017, 07:24 PM
  2. Advice required on Marshmallow update on Droid turbo.
    By burneehammad in forum Motorola Droid Turbo
    Last Post: 09-11-2017, 09:35 AM
  3. Why is my S8 stuck on decryption?
    By streek405 in forum Samsung Galaxy S8 & S8+
    Last Post: 09-10-2017, 01:03 PM
  4. How to change app order on app screen on android 6.0
    By Bloodeen in forum Legacy Android & Other OS's
    Last Post: 09-10-2017, 08:03 AM
  5. Replies: 2
    Last Post: 09-10-2017, 04:57 AM
