1. ShadowFlame's Avatar
    Hello,
    My LED light notification seems to only flash when I receive a Text Message or a missed phone call. Other than that it will not flash, the notifications appear in the notification bar and on the AOD. but things nothing else seems to flash the LED light besides Messages and Phone.
    I have made sure that all notifications are enabled under the LED light and everywhere else that pertains to notifications for all apps.
    Update: It also works with Hangouts, I did the LED test and all 3 colours work. But not with ebay or other apps.
    09-13-2017 09:59 AM
  2. D16RR's Avatar
    I had this issue. Turned the "always on" screen back on and that fixed it. I don't care for the always on screen, so if there is a work around to get notification for email without the always on screen, I'd like to know about it.
    09-25-2017 02:43 AM
  3. chanchan05's Avatar
    Try using Lightflow to control the light.
    09-25-2017 04:35 AM
  1. Fingerprint swipe for notification panel?
    By Fuzzystump in forum Samsung Galaxy Note 8
    Last Post: 09-15-2017, 09:54 PM
  2. HELP - Bixby not working
    By PhabPhan in forum Samsung Galaxy Note 8
    Last Post: 09-13-2017, 06:37 PM
  3. USB storage not being recognised
    By ArcturusNuva in forum Ask a Question
    Last Post: 09-13-2017, 12:39 PM
  4. How to make a legacy app (apk) work with Android 8?
    By android5problem in forum Ask a Question
    Last Post: 09-13-2017, 11:40 AM
  5. Replies: 1
    Last Post: 09-13-2017, 10:16 AM
