1. ivanwi11iams's Avatar
    Curious,
    - do you own an S8/S8 Plus?
    - do you use a magnetic stand in your car?
    - do you have a piece of magnet between the case and your phone?
    - do you use wireless charging?
    - do you use Samsung Pay or Google Pay?
    If yes to all the above, do you experience any issues?
    I'm wondering if the magnet between the case and the phone, would prevent the likes of wireless charging and using Samsung/Google Pay, working properly...?
    Thoughts...
    09-17-2017 06:00 PM
  2. PJRed2008's Avatar
    There's another thread in this forum almost identical to this from earlier this year IIRC. I'll see if I can find it...
    Look here: https://forums.androidcentral.com/sa...Magnetic+stand
    ivanwi11iams likes this.
    09-17-2017 06:17 PM
  3. ivanwi11iams's Avatar
    Hmm, seems if one uses a magnetic car mount, it will be a chore to get the wireless charging to work. A shame; but, I understand...
    09-17-2017 07:35 PM
  4. zyad's Avatar
    No, it can work.
    See my post at the end of this thread: https://forums.androidcentral.com/sh...d.php?t=800570
    Basically keep the metal plate near the bottom of the phone and the coils will still line up with your phones internals.
    09-17-2017 08:16 PM
  5. ivanwi11iams's Avatar
    Brilliant, thanks for the info...
    iFortWorth likes this.
    09-17-2017 08:23 PM
  6. RickMG's Avatar
    I use one and can't do the wireless charging because of it. I'm fine with that but it is a shame. S8+
    09-17-2017 08:27 PM
  7. zyad's Avatar
    You need to put the plate near the bottom of the phone. On my S8+ with the bottom of the Spigen rectangular plate about 1.5cm from the bottom of the phone still worked. On my Note 8 almost an inch from the bottom and it works.
    09-22-2017 07:52 PM
  8. RickMG's Avatar
    Thank you zyad I just did that, even though the phone isn't in a position that will be as convenient but hopefully it will work. I don't have a cordless charger but will try it in a few weeks when I'm at my brothers (he lives in Missouri, I'm in Florida) and if it works it will be fantastic. Thanks again.
    09-22-2017 10:30 PM
  1. Note 8 first sketches and doodles.
    By Anthony Martins Rock in forum Samsung Galaxy Note 8
    Last Post: 09-18-2017, 08:21 PM
  2. Very Good Camera and Batter Life, Excellent Patch Record
    By paullmas in forum Ask a Question
    Last Post: 09-17-2017, 09:50 PM
  3. Matches Puzzle with PVP system and chat
    By MogiLogi in forum Android Games
    Last Post: 09-17-2017, 02:08 PM
  4. Replies: 1
    Last Post: 09-17-2017, 01:47 PM
  5. Replies: 0
    Last Post: 09-17-2017, 01:17 PM
