1. freemansu's Avatar
    Dear all,
    I bought a samsung fast wireless charging pad (pn-920) recently. I tried charging my s8 plus for 4 hours(I turn off the phone and plugged a qc 2.0 charger for pad). The battery just went up from 10% to 87% (which is much slower than claimed speed). Do I need to turn on the phone during charging to achieve fast charge? Please advise. Thanks.
    Regards,
    Freeman
    09-22-2017 02:13 AM
  2. chanchan05's Avatar
    I think so. Fast charge has a software trigger. The charger and the phone will identify each other as fast charge compatible. Since the phone is off, then they can't do that.
    09-22-2017 02:54 AM
  3. SexyLi's Avatar
    You'd better use the original cable and the charger to charge your phone.
    09-22-2017 03:59 AM
  4. freemansu's Avatar
    Thanks will try charging for not turning off
    09-22-2017 07:19 AM
  5. freemansu's Avatar
    will try using original wall plug and cable as well thanks for advise
    09-22-2017 07:19 AM
  6. munnarg's Avatar
    Dear all,
    Regards,
    Freeman
    Did you check to make sure that fast charging is turned on in the settings?
    robmidi likes this.
    09-22-2017 07:49 AM
  7. robmidi's Avatar
    Dear all,
    Regards,
    Freeman
    Mine does. I have an Otter box case on it and it can only charge in the flat position, not standing. There seems to be a sweet spot on the phone to engage charging. I have to adjust placement to find it. Phone on or off, quick charge works great.
    09-22-2017 12:04 PM
  1. How do I change my default navigation app on Galaxy S8
    By Joeybass in forum Ask a Question
    Last Post: 09-03-2018, 07:12 AM
  2. Exchange settings reply and foward icons on email
    By rhurstfield in forum Ask a Question
    Last Post: 09-24-2017, 07:45 PM
  3. my xolo q900s is geeting switch off after screan look
    By keshav yawale in forum Ask a Question
    Last Post: 09-24-2017, 02:36 AM
  4. Battery draining fast!!
    By smooches680 in forum Samsung Galaxy Note 8
    Last Post: 09-22-2017, 04:13 AM
  5. HD calling on t-mobile with unlocked g5
    By Brent Michael in forum LG G5
    Last Post: 09-21-2017, 10:41 PM
