1. Dan 5369's Avatar
    I bought this phone at the beginning of the summer and all of a sudden during August the battery started draining faster when the display is on. Considering that I used to put the resolution on max and augmented brightness back when the battery was behaving normally, I can't say that doing those things are causing it to drain faster because I don't use those settings anymore and it is still draing fast and it is inconsistent with what the phone says it is draining the battery. This happens only when I use the display. I could play music from Spotify and blast it from a Bluetooth speaker for hours and the battery behaves normally. The phone also keeps telling me that I have a lot of hours left of battery life, but 1% battery drain takes away like 20 or 10 minutes.
    09-24-2017 01:18 PM
  2. spivet's Avatar
    Could be a change in your setting, one of your app update or system update that causes the additional battery drain. 1% battery drain in 20 or 10 minutes sounds ok, not unless you are used to seeing better numbers there.
    09-24-2017 03:47 PM
  3. Old g's Avatar
    Use your system's maintenance app
    09-25-2017 09:34 PM
  4. marco44's Avatar
    I have noticed the exact same thing. same timing
    09-25-2017 09:40 PM
  5. waveuk's Avatar
    Deactivate Google Location/History services.
    I had the same problem and this made a big difference.
    It is even scary to see how much data Google is collecting and sending. Even every time you open an app it will send details to Google.
    badcat likes this.
    09-26-2017 03:22 AM
  6. tuckertje01's Avatar
    Where can this be deactivated?
    09-26-2017 03:43 AM
  7. waveuk's Avatar
    settings / location / Google Location Histoy
    badcat likes this.
    09-26-2017 04:36 AM
  8. tuckertje01's Avatar
    Thanks!
    09-26-2017 06:44 AM
  1. Battery Life Seems To Be Getting Better
    By NotAnAppleGuy in forum Samsung Galaxy Note 8
    Last Post: 01-31-2018, 05:25 PM
  2. Why my Micromax A102 doesn't giving me respond?
    By 1sourav7 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-24-2017, 08:11 PM
  3. Nexus 6p After Battery Change!
    By ksu10061 in forum Nexus 6P
    Last Post: 09-24-2017, 03:09 PM
  4. Does anybody ever use ifixit.com? My brother swears by it.
    By rainman99336 in forum Ask a Question
    Last Post: 09-24-2017, 12:25 PM
  5. Samsung Trade-In
    By rtyler14 in forum Samsung Galaxy Note 8
    Last Post: 09-24-2017, 12:23 PM
