Nice phone but, unbeknownst to me, as of 6.0 some clown at google decided to kill push email to save battery. Does nobody get important, timely email anymore?
1. Samsung's Email app will get push if AOD is on. At least as far as I can tell. But I gave Greenify handling Doze so it can be set to aggressive (20min trigger instead of 1hr), and have set Samsung email as exception there.Interestingly, samsung's mail app is there by default and can't be moved. That app absolutely will will not get push notifications until you open it. Not always, but often enough to indicate they made some changes, and not for the better. Gmail? Did they ever fix that app it so it just delivers email without the Apple-like need to arrange it as they see fit?
