1. bobby35ny's Avatar
    Lets say your internet goes down in your home WIFI network. The phone should go right to mobile data. My S8+ does not switch, even if I use the smart switch stuff.
    I have to turn off wifi completely on my phone to use mobile data.
    09-30-2017 09:46 PM
  2. Almeuit's Avatar
    It depends. Is your internet going down but wifi staying connected? If so it won't insta switch since it still sees the wifi network.
    09-30-2017 11:54 PM
  3. bobby35ny's Avatar
    Well ya, I walk out to the driveway, the wifi is on the edge out there, I'm connected to wifi but too far for internet.
    its 2017, LOL the phone should move me to mobile data if there is a problem with wifi...
    10-04-2017 12:35 PM
  4. Philipmom's Avatar
    Under smart network switch, try turning on more aggressive switching. It should make it swap faster when wifi is weak.
    10-04-2017 01:30 PM
  5. bobby35ny's Avatar
    I tried aggressive switching, That didn't help.
    10-04-2017 06:06 PM
  6. ABOSWORTH007's Avatar
    I hear what you're saying but if it did this, then people would be complaining about how the phone was using data while they were connected to WiFi.
    10-05-2017 08:47 AM
  1. How to change a sd card from transferring photos to internal?
    Last Post: 10-04-2017, 03:12 AM
  2. Replies: 6
    Last Post: 10-02-2017, 10:14 AM
  3. My phone won't won't let me answer in coming call's
    Last Post: 10-01-2017, 01:00 PM
  4. Galaxy s8 camera turns vertical pics horizontal in Gallery
    Last Post: 10-01-2017, 01:38 AM
  5. Replies: 2
    Last Post: 09-30-2017, 10:11 PM
