1. anon(8312128)'s Avatar
    T-Mobile S8+ ...
    My Default Notification sound ("beep once") keeps going off, seems like every couple of minutes, but there's no new notification. I keep getting the beep, pull down the notification shade, and there's nothing there (??)
    I've searched through notification settings and can't figure it out - why I keep getting the sound but no new actual notification.
    Thanks in advance
    10-03-2017 12:25 AM
  2. SpookDroid's Avatar
    Did you recently format the phone or have connected it to a BT device that is now 'forgotten' on your phone? Incoming BT connection requests from previously paired devices are a very common cause for these 'phantom' notifications.
    10-03-2017 01:50 AM
  3. anon(8312128)'s Avatar
    Nope, hasn't been connected to any BT device as of yet - phone is brand new. I guess I'm just going to have to keep an eye on it and watch it. Did several restarts but that didn't make a difference.
    10-03-2017 02:21 AM
  4. anon(8312128)'s Avatar
    Still happening ... both while the screen is on, and while on AOD screen. Phantom alerts sounds. There's gotta be a way to fix this - something is wrong.
    10-03-2017 11:01 AM
  5. Gayle Lynn's Avatar
    Stuck "keys?" Is there Pressure on screen, On edge? Apps placed on edge maybe?
    Is it in a case? Take it out. If not, try using a case.
    One feature I love is you can set notification of apps to Silent. Miss that from my iOS days.
    (This is only my 2nd day with S8+ and still finding options to customize).
    I did have trouble with apps moved into SecureFolder..
    10-03-2017 11:35 AM
  6. SpookDroid's Avatar
    I'm sorry to keep pushing this, but have you tried turning BT off?
    10-03-2017 11:51 AM
  7. anon(8312128)'s Avatar
    BT isn't on ...
    10-03-2017 11:55 AM
  8. anon(8312128)'s Avatar
    I might be on to something here, but maybe not. Could it be Google Assistant Reminders? I recall having several reminders sitting in my notification shade when this is happening. Not sure how Google Assistant Reminders are programmed to work, but maybe they persistently alert you until you acknowledge the reminder in some way? And if that's the case, is there a way to change that behavior in Google settings .... ?
    Problem seems to come and go at this point, but it definitely doesn't seem normal to get alert sounds with no actual notification or anything happening. That sounds like a bug.
    10-03-2017 01:37 PM
  9. SpookDroid's Avatar
    Ok, so you do have notifications in the notification area? Have you checked that the notification reminder setting isn't on (this would cause your phone to alert you again and again periodically when you have unread notifications)?
    If the reminders are the ones causing it, you should be able to see your reminders in the Google app.
    10-03-2017 02:26 PM
  10. anon(8312128)'s Avatar
    I think you nailed it. I DID have Notification Reminder turned on and set at 1-minute intervals. I don't know why I turned this on. I wonder if it was turned on by default out of the box ... ?
    Anyway, thank you!! I'm sure this is the culprit - I cant imagine it being anything else.
    SpookDroid likes this.
    10-03-2017 02:43 PM
  11. anon(8312128)'s Avatar
    It is nice to know, however, that you CAN turn that on if you ever DO want a repeating reminder for something.
    10-03-2017 02:46 PM
  12. SpookDroid's Avatar
    Hope that worked! If I'm not mistaken, you can also fine-tune which notifications you want to be reminded of, so not all apps will do it if you don't want to. (I think you can in the Note 8, don't see why it would be different on the S8 Line).
    10-03-2017 03:18 PM
  1. Notification Reminder
    By ROE_HUNTER in forum Samsung Galaxy Note 8
    Last Post: 01-27-2018, 06:31 PM
  2. Very low sound out of left ear bud
    By Paul5190 in forum Samsung Galaxy S8 & S8+
    Last Post: 10-02-2017, 07:41 PM
  3. Replies: 7
    Last Post: 10-02-2017, 05:00 PM
  4. Not getting notification on samsung galaxy on 5 6
    Last Post: 10-02-2017, 02:33 PM
  5. Very low sound out of left ear bud
    By Paul5190 in forum Ask a Question
    Last Post: 10-02-2017, 11:50 AM
