1. Darth Mo's Avatar
    I purchased the set linked below three months back or so. Already, one of the cables that was maybe used 20 times doesn't charge at all, and there is another that will only fast charge if oriented one way, so I assume it will fail completely soon. Also, I'm randomly getting the "Incomplete connection" warning, which requires re-connecting it to get it to charge properly.
    I had resigned to the fact that micro USB-B cables were fragile, so I would just replace them and move on. These USB-C cables are much more fragile it seems, so I'm hoping I just chose ones of poor initial quality.
    What cables have people had better luck with?
    https://www.amazon.com/Ofspower-Braided-Charging-Aluminum-Connector/dp/B06W2KH5NS/ref=cm_cr_arp_d_product_top?ie=UTF8
    10-04-2017 11:19 AM
  2. joeldf's Avatar
    I got a set of Amazon Basics cables. Seem a bit sturdier than the really thin and cheap feeling cable that came with my S8.
    10-04-2017 12:44 PM
  3. jacker's Avatar
    I use yootech , Anker and aukey .
    All still work.
    10-04-2017 12:53 PM
  4. Gayle Lynn's Avatar
    Fast charges. Was for my BlackBerry DTEK60. IT IS thick solid cable.
    https://www.amazon.com/gp/product/B0...cUvbUpU6004021
    I found "thick beaded cables" to be worthless gimmick.
    10-04-2017 01:01 PM
  5. WallaceD's Avatar
    Anker.
    These are rock solid, in my experience.
    https://www.amazon.com/Anker-PowerLi...cUvbUpU6004065
    10-04-2017 01:21 PM
  6. Gayle Lynn's Avatar
    "will not charge Nintendo Switch, Nexus 5X or 6P, Moto Z, Huawei Mate 9,..." So I skipped. Had trouble with some phones using Anker.
    10-04-2017 01:37 PM
  7. WallaceD's Avatar
    10-04-2017 01:50 PM
  1. Verizon pricing confirmed for V30
    By sofryj in forum LG V30
    Last Post: 10-05-2017, 04:44 AM
  2. Permission for account
    Last Post: 10-04-2017, 09:11 AM
  3. Samsung J1 not connecting to PNY Duo-Link USB 3.0
    Last Post: 10-04-2017, 05:24 AM
