Meh. Even actual digital cameras have crap digital zoom. I got a 14mp Sony Cybershot here to prove that.To be fair. Majority, if not all digital zoom is crap quality on smart phone devices.
If you're doing digital zoom, you may want to adjust focus and your distance. There's a lot of different factors at play here and there's also the difference in fixed focal length of the cameras of the 5s and your current phone. That means you can't just do the same things without a little adjustment in terms of either your distance from the object or the software tweaks to get the same image quality. There's also how the digital zoom is processed. Different cameras have different default software presets. iPhone camera software tend to have higher contrast by default so text is clearer in software processing. Of course you can always toggle this in settings, or use a dedicated app for taking pictures of text.I never had this issue with my IPhone 5s surprisingly.. I always zoom, that's how I give and transfer answers to help others with notes.
This function is built into Google Drive. Open Drive, tap the plus button in the lower right corner, tap scan, center the page in the viewfinder, take the picture. If it looks good, save it. Sometimes the auto crop function cuts off part of the page. In that case retake the scan from slightly further away.If we're talking about taking pics of documents, then another option instead of the Optical Reader app is one of the PDF apps like Tiny Scanner. This app allows you to take pics of documents within the app and turn them into PDF's instantly. The app removes all shadows/shade from the white part of the paper, and then clears up all the text and makes it look like you basically scanned the document with a real scanner. You can also use a pic from your phone and convert it to a PDF, so you'll have both options (the pic and the PDF) to use depending on how you want to send the file to someone.
