1. diegoaccord's Avatar
    Hi are there any fixes for this that doesnt need root? Samsung must have some kind of EQ or visualization for the sound, because it gets much lower when I want to listen to music. No matter what you do, as soon as music plays the phone quiets, and I looked and saw old unresolved threads. Regretting this phone due to this issue.
    Thanks
    10-14-2017 02:42 AM
  2. bandofbrothers2112's Avatar
    I do have some issues when listening to videos because of the single bottom firing speaker which usually pushes me to using earphones !
    10-14-2017 02:47 AM
  3. tuckertje01's Avatar
    No sound problem here...
    10-14-2017 07:22 AM
  4. diegoaccord's Avatar
    No maybe you dont think it sounds bad but there is auto-leveling which greatly reduces the sound level. Even if you install EQ apps and gainers, the phone overrides them. You'll hear it at the desired level for a SPLIT second before the volume nerfs again.
    10-14-2017 09:00 PM
  5. paridge's Avatar
    Have you tried equalization? One way to do that is through Google Play Music. You'll have the option of going to the advanced menu where you'll be able to make adjustments for each ear as well.
    10-14-2017 09:26 PM
  6. Jackhklee's Avatar
    Atleast we got a headphone jack... I never use the speaker.. If there is someone in the room, I find it disrespectful and annoying to be playing sound out loud. Gs8 has Bluetooth 5 so if you want to blast music or something, get a Bluetooth speaker.
    10-15-2017 10:58 AM
  7. diegoaccord's Avatar
    Im not talking about the speaker genius. Bluetooth to car...
    10-15-2017 09:46 PM
  8. Doug Moffat's Avatar
    If it's Bluetooth to car system I'd visit my carrier asap. Not an audiophile but never had a problem with music using wired connection.
    10-15-2017 10:11 PM
  9. Jaycemiskel's Avatar
    My Bluetooth to car is fine. I have no problems. It gets plenty loud, like loud enough for me to get a ticket for noise pollution if I turn it all the way up. Are you sure there's nothing wrong with the phone?
    10-15-2017 10:25 PM
  10. sweetypie31's Avatar
    You didn't specify what you meant so that's probably why that poster thought you were talking about the speaker.
    Jackhklee likes this.
    10-16-2017 07:03 AM
  1. Is there something like this for Pixel XL 2??
    By ihbsbA in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-18-2017, 08:37 PM
  2. my samsung gallery is not responding
    Last Post: 10-14-2017, 05:32 PM
  3. Replies: 1
    Last Post: 10-14-2017, 05:23 PM
  4. Why is there a circle with a plus sign on my desktop
    Last Post: 10-14-2017, 05:20 PM
  5. Why is my S8 can't download from play store?
    Last Post: 10-14-2017, 09:54 AM
