1. Kaushal Baruah's Avatar
    Im having problems with my pixel launcher apk...I mean it works fine but its suddenly not displaying apps on the app drawer...don't know why....do I have to uninstall it and then reinstall it...cuz I tried reinstalling it but didn't work.....how do u uninstall an apk by the way?
    10-17-2017 12:03 PM
  2. B. Diddy's Avatar
    Moved from the Nougat forum to the S8 forum.
    10-17-2017 04:26 PM
  3. Kaushal Baruah's Avatar
    ok..thanks for replying
    10-17-2017 04:37 PM
  4. Kaushal Baruah's Avatar
    so can anyone tell me why?
    10-17-2017 04:39 PM
  5. B. Diddy's Avatar
    It's probably not entirely compatible with your phone. Does it show up as compatible in the Play Store? (I'm guessing it doesn't.)
    You can uninstall it by going to the App Manager, selecting Pixel Launcher, and uninstalling there.
    10-17-2017 04:51 PM
  6. Kaushal Baruah's Avatar
    oh ya..I figured out how to uninstall it..... then I reinstalled it and it's still the same...and btw it's an apk...so I dont think I can know whether it's 100% compatible with my s8 or not....but I downloaded it from the xda page and it was meant to be used for an s8...Ive reverted to the stock launcher tho
    10-17-2017 05:01 PM
  7. B. Diddy's Avatar
    Exactly -- that's why its availability on the Play Store is a good indicator for compatibility.
    10-17-2017 05:34 PM
  8. Kaushal Baruah's Avatar
    ok tyanks
    10-17-2017 05:40 PM
  9. mustang7757's Avatar
    10-17-2017 07:40 PM
  10. mustang7757's Avatar
    That's the link to use pixel 2 launcher and choose the 1.6 latest apk
    10-17-2017 07:41 PM
  11. Kaushal Baruah's Avatar
    Thank you for sharing...I'll try it out and will let u know if it works
    mustang7757 likes this.
    10-17-2017 07:50 PM
  12. Kaushal Baruah's Avatar
    I installed it and it's working really fine.... Thanks a lot once again! 😊
    B. Diddy likes this.
    10-17-2017 11:39 PM
  13. mustang7757's Avatar
    I'm glad I could help, also in this new APK if you go into launcher setting it has dark theme . enjoy
    10-17-2017 11:44 PM
  1. What does it mean on the screen you have disabled a required permission.
    Last Post: 10-17-2017, 01:03 PM
  2. Will the Google Pixel still be good for 2018?
    By Crysoll in forum Ask a Question
    Last Post: 10-17-2017, 12:43 PM
  3. Power Saver on Note 5 changed my resolution and it won't revert back?
    Last Post: 10-17-2017, 12:26 PM
