    what could be the reason..hkw can i turn off low batter mode.
    10-25-2017 02:36 AM
  2. worldspy99's Avatar
    It is trying to conserve power. Can you post a screen shot?
    10-25-2017 10:23 AM
  3. AndroidFan3420's Avatar
    I guess that it goes automatically into power saving mode. Processor speed will be limited at 70%. You can turn of power saving mode in the notification panel or through settings.
    10-25-2017 10:49 AM
  4. Rukbat's Avatar
    It's working the way it should but you're not. You should never let the battery drop below 40%. (Lithium batteries are not deep discharge batteries.) When it gets down to 40%, either charge it or shut it off (or get used to sending it in for a battery replacement every few months).
    AndroidFan3420 likes this.
    10-25-2017 11:15 AM
  5. AndroidFan3420's Avatar
    40-80 rule
    10-26-2017 12:04 AM
  1. galaxy s8+ slow and stuck and hanging when battery is less than 20%
    Last Post: 10-26-2017, 02:37 AM
  2. Why isn't the search bar causing burn -in or IR?
    By Garemlin in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-25-2017, 12:46 PM
  3. Phone starts rebooting and crashing google apps.
    Last Post: 10-25-2017, 07:39 AM
  4. headset and speaker problem
    Last Post: 10-25-2017, 01:18 AM
  5. why is my storage so low
    Last Post: 10-25-2017, 01:17 AM
