    Because some smart person decided not to put a cover over the charging port. Clean the dust and lint from the charging port.
    11-19-2017 01:57 PM
  2. belodion's Avatar
    Well, that’s one possible cause perhaps, though I’ve never had the problem myself, and I think that most charge failures in devices in general are not because of that.
    11-19-2017 04:18 PM
  3. wxboss's Avatar
    This is a shot in the dark so take it for what it's worth.
    I believe the Samsung + app (if you have it installed), in the diagnostics section where it gives you an overall performance rating, if you click on that, it should list many things that it watches and one of them is the phone/charger connection. Maybe looking into that might offer you some insight?
    11-19-2017 06:37 PM
  4. illdini's Avatar
    The problem could be:
    • bad charger
    • bad charging cable
    • loose cable connection to charger and/or phone
    • Fast Charging setting not set
    I would try to charge with a known good charger and cable, then troubleshoot from there.
    11-20-2017 06:57 AM
  1. how do I get the roku Ir remote off my lock screen
    Last Post: 09-28-2018, 07:51 PM
  2. WeChat Video Calling is too loud on Pixel 2
    By Randomx999 in forum WeChat for Android
    Last Post: 11-26-2017, 07:29 AM
  3. What is using so much memory?
    By cityten in forum Ask a Question
    Last Post: 11-24-2017, 10:58 AM
  4. Incipio Octane Case for the Galaxy Note 8
    By DecAway in forum Samsung Galaxy Note 8 Cases & Accessories
    Last Post: 11-19-2017, 12:38 PM
  5. My girlfrind is pregnant and she's cheating
    By mgod26101 in forum Ask a Question
    Last Post: 11-19-2017, 11:49 AM
