1. srfoot's Avatar
    Hi;
    When I press "Clear All" on the bottom right of my notification screen (which is next to Block Notifications) it makes a clicking sound for each item it is deleting from the notifications.
    Is there a way to stop the sounds from doing this without affecting any other sounds?
    Thank you.
    11-26-2017 12:17 PM
  2. mary beth hale's Avatar
    Do you have touch sounds enabled in settings? That will give you a noise every time you tap your screen. I don't think you can specify which taps will elicit a sound.
    11-28-2017 08:37 AM
  3. srfoot's Avatar
    Hi;
    Touch sounds are disabled. It is after I click "Clear All" on the drop down notification screen.
    Thank you.
    11-28-2017 03:32 PM
  4. mary beth hale's Avatar
    Hi;
    Thank you.
    If touch sounds turned off then I'm stumped. Sorry.
    11-28-2017 05:41 PM
  1. Is there a way to get a back slant on my Galaxy S3 tablet?
    By Michael Kingsbury in forum Samsung Galaxy Tab S3
    Last Post: 11-26-2017, 05:05 PM
  2. my phone is not start on but display logo "micromax android"
    Last Post: 11-26-2017, 01:39 PM
  3. I want to clear the cache of my metro pcs pro phone. It is a Z981 android phone.
    Last Post: 11-26-2017, 01:25 PM
  4. What is the reset password for private mode on my samsung s7 edge?
    Last Post: 11-26-2017, 12:37 PM
  5. How do i uninstall andtoid updates on my samsung cell i hate the screen changes
    Last Post: 11-26-2017, 12:33 PM
