1. alexcapone's Avatar
    Sometimes I want to capture a photo in a very quick moment and when I open the camera I want it to open the rear facing camera so I can quickly take the photo. Is there a way to default the camera setting to open the rear facing camera? I think it opens the camera that was used to take the last picture. I am looking for a way to change that setting.
    12-01-2017 12:41 PM
  2. Ecm's Avatar
    Sorry, there's currently no such setting.
    12-01-2017 01:02 PM
  3. joe_fresh's Avatar
    Mine opens on the last one I had it on. So if you are taking a ton of selfies and close out the app on the selfie cam. It will open on that one.
    12-01-2017 03:20 PM
  4. mlblack16's Avatar
    it should default to the last camera setting you had open.
    you may try going into app manager, camera, then delete cache and even data (which will remove any custom settings and restore to as it was when you first opened the app).
    12-01-2017 03:53 PM
  1. How to disable AppFlash in newest Z Force update
    By YAYTech in forum Moto Z Force
    Last Post: 05-20-2018, 10:34 AM
  2. Account action required, I need to remove this notification
    Last Post: 03-18-2018, 06:57 AM
  3. Replies: 1
    Last Post: 12-01-2017, 09:14 PM
  4. How to retrieve already saved contacts that disappeared?
    Last Post: 12-01-2017, 11:30 AM
  5. Is there any way to put covers on my Samsung notes?
    Last Post: 12-01-2017, 10:16 AM
