1. Pavel Vanousek's Avatar
    Hi there, since about mid November I am struggling with Google Services (11.7.46, 11.9.51) consuming up to 30% of my battery, eating 3hours of CPU every day. The issue can be sometimes mitigated for several hours by restart. I switched off synchronization and location services, switched off google now, stopped synchro for Samsung account. but it does not help. The only thing that helps is a downgrade ('uninstall updates') to version 11.5 but then my Google Inbox application does not work (notably, one of only few apps that cannot cope !). I guess this must be some 3rd party app - is there any way whatsoever how to identify which app is causing this?
    12-05-2017 11:20 AM
  2. beermode's Avatar
    I am going through the same thing on my Pixel 2. And I bet you are connecting to a wireless network with a mesh topology. That seems to be theme so far. I've also noticed it's on 835 chipsets.
    They didn't do their homework while they building their intrusive/persistent wireless scanning, localization and data gathering.
    12-05-2017 12:03 PM
  3. Pavel Vanousek's Avatar
    Thanks, but this is happening with or without WiFi. Today 45min CPU consumed by Google Services in 1 hour since I switched the phone on. With location, synchronization AND mobile data & WiFi switched off !
    12-06-2017 02:13 AM
  1. Can I manually update my Nexus 6 to Android 8?
    By Mary Ann Gonzalez in forum Android 8.0 Oreo
    Last Post: 12-08-2017, 10:55 AM
  2. Stock Android app has stopped running how do I fix this problem
    Last Post: 12-05-2017, 11:59 AM
  3. Swype keyboard not working with Google Search
    By Jon44 in forum Samsung Galaxy Note 10.1
    Last Post: 12-05-2017, 08:14 AM
  4. Google Services excessive CPU consumption Android 7.0 on S8
    Last Post: 12-05-2017, 08:02 AM
