1. gsilver0's Avatar
    I'm suddenly seeing the process "audioserver" at the top of the battery usage list. It says that since my last full charger ~23 hours ago, it has used the CPU for 6h 37m 28s and has 14h 54m 5s stay awake time.
    The only program that I installed recently was Google Voice, which I uninstalled after seeing this problem, but the problem did not go away.
    I read elsewhere to disable "AudioConnectionService" but that made no difference.
    12-08-2017 11:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this persist after a reboot? If so, then I wonder if it's similar to Mediaserver issues that are related to a corrupt media file somewhere. You may want to try backing up any music files saved locally on the phone, and then deleting them all.
    12-08-2017 02:41 PM
  3. gsilver0's Avatar
    It did persist after a few reboots in the last few days.
    I do not have any music files on the device
    The only media on the device is a couple of short videos that I recorded with the camera app.
    I've deleted the cache partition this afternoon. I'll update tomorrow whether or not that stopped the problem.
    12-08-2017 02:50 PM
  4. B. Diddy's Avatar
    Ok, try also backing up those videos somewhere and then deleting them from the phone, in case one of the files got corrupted.
    mary beth hale likes this.
    12-09-2017 12:27 AM
  5. gsilver0's Avatar
    I figured it out:
    I had installed Rayman Fiesta Run and Rayman Jungle Run on my phone a while ago. Recently, after finishing Jungle Run, I moved on to Fiesta.
    Jungle Run was well behaved and only drained battery when in use.
    Fiesta, on the other hand, spawned the audioserver process in the background, and a bug was causing the battery to drop off like I had been seeing. The only way to stop it was to force close the program.
    I uninstalled Fiesta Run, and the problem has gone away.
    mary beth hale and B. Diddy like this.
    12-13-2017 11:27 AM
  6. mary beth hale's Avatar
    That's great
    12-13-2017 12:00 PM
  1. What is proxy processor and could it be causing my recent troubles?
    By Essie1 in forum Android 6.0 Marshmallow
    Last Post: 12-10-2017, 01:51 AM
  2. S8 Battery Draining Real Fast All Of a Sudden.
    Last Post: 12-08-2017, 08:50 PM
  3. j5 prime just froze no buttons responding non removable battery
    Last Post: 12-08-2017, 02:51 PM
  4. Replies: 1
    Last Post: 12-07-2017, 11:50 AM
  5. Replies: 1
    Last Post: 12-07-2017, 04:11 AM
