    I have seen some reviewers say that most glass screen protectors will pop off when putting on a spigen ultra hybrid case for the samsung galaxy s8, is this the same situation for a plastic/non glass screen protector ?
    12-09-2017 06:43 AM
  2. mundo472's Avatar
    there are a couple good poly screen protectors that are cut for cases. the ones I've used from best skins ever work really well but the application has to be spot-on. also, it helps to do it in a well-steamed bathroom and to moisten your fingertips to avoid lint getting caught on the sticky side. if you do notice it, you can peel it off, wash it, and reapply.
    12-12-2017 08:28 PM
  3. mundo472's Avatar
    oh, and order at least two, as they are cheap and you will feel better for it when you realize you did everything exactly right but the next morning there is a dog hair you missed under the screen protector.
    12-12-2017 08:30 PM
  4. jeffmd's Avatar
    I do not think he was referring to polyurethane skins.
    12-15-2017 09:16 PM
  1. Blackberry hub not working
    By neoberry99 in forum Samsung Galaxy Note 8
    Last Post: 12-12-2017, 03:11 PM
  2. Where do the music links that I save go to on my cell phone
    Last Post: 12-09-2017, 02:18 PM
  3. Replies: 0
    Last Post: 12-09-2017, 05:44 AM
  4. ultra power issues with Infinix note 2
    By Shally1 in forum Legacy Android & Other OS's
    Last Post: 12-09-2017, 04:32 AM
