1. Sammytheorangutan's Avatar
    Has anyone used a battery case from Alpatronix? Their 4k mAh case is cheaper than the ZeroLemon and it appears much smaller. Also, the Alpatronix case is compatible with Qi wireless charging where the ZeroLemon doesn't claim to be.
    HAGO!
    12-10-2017 09:51 PM
  1. Replies: 13
    Last Post: 03-07-2018, 01:12 PM
  2. Phone Case Suggestions?
    By Aithan in forum LG V30
    Last Post: 12-30-2017, 08:51 AM
  3. Can I use a rapid charger on my Tab s2 without causing damage to the battery?
    Last Post: 12-10-2017, 02:40 PM
  4. ZeroLemon extended battery review
    By datum9 in forum Samsung Galaxy S8 & S8+
    Last Post: 12-10-2017, 02:29 PM
  5. Battery drain help
    Last Post: 12-10-2017, 11:48 AM
