    Recently got an S8 and sometimes it shows Emergency Calls Only. Usually it will show LTE or E and work just fine, but occasionally it will switch to just plain signal bars and won't let me make calls or anything. I can go into my settings and search for and select T-Mobile as my network and that will often fix it.
    I'm thinking that this is just the phone detecting other networks like Sprint or AT&T and showing that I can call 911 or something when I don't have T-Mobile coverage. While handy, it's pretty annoying to see signal bars but not be able to do anything.
    Just wanted to confirm that this was indeed the case. I really don't think it's a hardware issue (if any issue at all) because I usually do get usable LTE or E coverage (No 3G though it seems).
    The phone is a Samsung Galaxy S8 Factory Unlocked running on Tracfone with a T-Mobile compatible SIM.
    12-13-2017 01:16 PM
  2. mary beth hale's Avatar
    Did you input the correct APNs? Sounds like it's dropping service.
    12-13-2017 02:06 PM
  3. M_W's Avatar
    It automatically entered the APN when I put in the SIM.
    12-13-2017 02:50 PM
  4. mary beth hale's Avatar
    OK. Not that then.
    12-13-2017 03:22 PM
  1. Autospace Doesn't Work in Chrome using Swipe Keyboard
    By DLCPhototography in forum Samsung Galaxy Note 8
    Last Post: 04-14-2018, 09:18 AM
  2. Replies: 3
    Last Post: 01-16-2018, 05:16 AM
  3. Android: Google Keyboard: Autocorrects "I ..." to capitalize next word, no "I".
    Last Post: 12-14-2017, 11:47 AM
  4. Replies: 1
    Last Post: 12-13-2017, 07:54 PM
  5. delete call history
    By dxb68886 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 12-13-2017, 12:52 PM
