    Problem appeared with the famous moisture detected issue. The notification of moisture disappeared and now when the device is plugged, the fast charging appears for 5-10 seconds then it switch to cable charging.
    Tried all the solutions in this forum nothing worked.
    12-25-2017 12:24 PM
  2. NeilMex's Avatar
    I had this issue and it turned out that the cable wasn't plugged into the wall charger completely.
    Hope this helps.
    12-25-2017 09:24 PM
  1. Replies: 2
    Last Post: 12-30-2017, 10:07 PM
  2. andriod or iphone Automatically Switch to the Strongest WiFi Network without app
    Last Post: 12-25-2017, 12:21 PM
  3. Hi! I have a Samsung Galaxy 7 Edge and trying to add a bitmoji to a group text.
    Last Post: 12-25-2017, 11:59 AM
  4. Why has the date changed to 25th of demon? Weird Alcatel problem
    Last Post: 12-25-2017, 10:07 AM
  5. Side Lock Button Appears to be Malfunctioning on my S8
    By omelet1978 in forum Samsung Galaxy S8 & S8+
    Last Post: 12-25-2017, 09:53 AM
