1. zach1301's Avatar
    Whenever I connect any usb stick to my galaxy s8 it just brings up a notification saying connected device charging. When I change it to transfer files it just resets and goes back to charging? Any help? It's driving me bonkers!!
    12-30-2017 03:31 AM
  2. Rukbat's Avatar
    You need an OTG adapter or cable to connect a USB stick to an Android device. (They're cheap, if you're willing to wait - there are a lot of them on eBay from China for 99 cents including shipping.)
    12-30-2017 03:53 PM
  3. Alvdan88's Avatar
    Im assuming your using the USB dongle samsung provided. All adapters should work. if its giving you the option to switch to "Transfer". Maybe the dongle is bad. any electronics store has them for a couple bucks. ALSO if your USB is not FAT32 or NTFS it wont be able to read its files.
    01-04-2018 12:18 PM
  1. Why is my galaxy s3 not charging sometimes?
    By ld5596 in forum Ask a Question
    Last Post: 12-31-2017, 12:24 PM
  2. How to connect gaming headset to android phone?
    By android_beginner in forum Ask a Question
    Last Post: 12-30-2017, 09:57 PM
  3. S8 won't charge with Fast-Charfe adaptor
    Last Post: 12-30-2017, 04:29 PM
  4. How to connect a samsung gear s3 to PC ?
    By Android Central Question in forum Samsung Gear S3
    Last Post: 12-30-2017, 09:42 AM
  5. How can I have hotspot settings on my galaxy s8+ sprint unlocked
    Last Post: 12-29-2017, 08:51 PM
