    I lose more then 4% in 35min and i did near to nothing, except Whatsapp. And I lost last night while i slept 4% (in 8 hour) although i dont use the Always-On-Display
    01-01-2018 09:06 AM
  2. belodion's Avatar
    What did your battery usage stats indicate as the cause in the first case?
    A 4% loss overnight is not necessarily cause for concern, and for some users, would be welcome.
    01-01-2018 09:38 AM
  3. FlyingTerlik's Avatar
    The Screen and Snapchat, during the night it was the phone alone on standby and the battery on standby
    01-01-2018 10:07 AM
  4. belodion's Avatar
    Okay. Welcome as a new member.
    It sounds normal enough to me but I’ll move the thread to the S8 forum for comments from other users.
    01-01-2018 10:29 AM
  5. FlyingTerlik's Avatar
    Okay, thanks ^^
    01-01-2018 11:21 AM
  6. Wbutchart's Avatar
    If you are worried at all download accubattery from Google play, it will show you detailed usage and how your battery is doing.
    01-01-2018 02:07 PM
  7. mary beth hale's Avatar
    Wouldn't consider 4% overnight excessive.
    01-01-2018 08:53 PM
  1. Unable to access/upload some images on my phone (Lenovo Zuk Z2131) from PC
    Last Post: 01-01-2018, 03:45 PM
  2. Why I cant change my network to 4G/Lte only
    Last Post: 01-01-2018, 03:14 PM
  3. Why is turning on Ok Google detection buggy?
    Last Post: 01-01-2018, 08:52 AM
  4. Why did my phone start beeping like a smoke detector?
    Last Post: 01-01-2018, 08:46 AM
  5. Replies: 0
    Last Post: 01-01-2018, 08:36 AM
