1. randyb19's Avatar
    Any app recommendations for replacing the standard DND? I'm looking for stronger customization, particularly on/off times for weekdays versus weekends.
    01-22-2018 05:59 PM
  2. Mattsg430's Avatar
    Tasker may be a good solution for you.
    01-22-2018 06:10 PM
  3. mary beth hale's Avatar
    Would also suggest Tasker if you want more granular control. I don't currently use it but did about 2 years ago for about 6 months.
    Something of a learning curve but you can control a large variety of actions on your phone.
    Laura Knotek likes this.
    01-22-2018 06:46 PM
  4. azjerry's Avatar
    Agree that Tasker is what you need.
    01-23-2018 03:44 PM
  5. randyb19's Avatar
    Thanks. Will give it a try.
    mary beth hale likes this.
    01-23-2018 09:51 PM
  6. ChriRicerockets Rice's Avatar
    Do Not Disturb by Cabooze had worked well for me.
    01-24-2018 11:40 AM
  7. Feldhege's Avatar
    Timeriffic can do that kind of things.
    01-24-2018 02:04 PM
  8. randyb19's Avatar
    This works great! Thanks for the info.
    01-26-2018 04:17 PM
  1. Why is the internal keyboard not popping up?
    Last Post: 01-23-2018, 04:36 AM
  2. Why am I not able to set music as my text message notification?
    By Latisha Lucas in forum Ask a Question
    Last Post: 01-23-2018, 01:02 AM
  3. Wgat dies it mean to ru ur app and hoe do u do it
    Last Post: 01-22-2018, 06:17 PM
  4. Not Optimized Battery Setting Not Being Respected
    By belanger in forum Android 8.0 Oreo
    Last Post: 01-22-2018, 05:25 PM
  5. Replies: 0
    Last Post: 01-22-2018, 04:44 PM
