1. PatrickBaterman's Avatar
    Hi,
    I'm the proud new owner of a S8...amazing phone! But let's get right to the point. I know you can change some settings for your speakers. Does anyone has some good settings for me?
    The sound of the S8 is ok but in my opinion not better than my previous phone, the S6.
    01-28-2018 08:13 AM
  2. N4Newbie's Avatar
    Are we talking about music?
    If so, what player are you using? Try one with a good equalizer built-in, such as PowerAmp, and then play around with the equalizer settings to find your personal sweetspot.
    01-28-2018 08:48 AM
  3. PatrickBaterman's Avatar
    Yes, music. Mainly through Spotify or the standard Samsung music player.
    01-28-2018 09:27 AM
  4. chanchan05's Avatar
    The speakers on the S8 (and S7) are a bit muffled because they're really not special to begin with then Samsung put a water resist film over it.
    I suggest you just run Adapt Sound so as the phone will configure its sound according to your own hearing profile.
    01-28-2018 09:49 AM
  5. PatrickBaterman's Avatar
    I just had quick look through the Adapt Sound app in the store, isn't that only for sound if you have headphones connected? I need a app for the main speaker without any headphone plugged in.
    01-28-2018 10:25 AM
  6. Dooki's Avatar
    Your best bet is to get a small bt speaker. I got a waterproof one for about $30 and the sound is good, not great.
    The internal speaker is not very good. There is really not much you can do to make it sound better.
    01-28-2018 02:20 PM
  1. speaker problem
    Last Post: 01-28-2018, 02:04 PM
  2. Why is Snapchat front camera quality so much worse than normal?
    Last Post: 01-28-2018, 05:43 AM
  3. How do I get sound to work with/for my GIFs in text messages?
    Last Post: 01-27-2018, 10:48 PM
  4. Jan 2018 Security and performance improvement update now live.
    By Nodnerb in forum Axon 7 & Axon 7 mini
    Last Post: 01-27-2018, 08:04 PM
  5. How to improve volume when watching Amazon Prime
    Last Post: 01-27-2018, 06:54 PM
