1. JC8865's Avatar
    I downloaded a font from the Web but can't figure out how to install it. Any help would be great. Thanks
    JC
    02-15-2018 03:23 PM
  2. SpookDroid's Avatar
    It has to be the right font format and I believe you can only install those either from the Samsung store (Galaxy Apps) or from the Play Store, not just a computer font file.
    JC8865 likes this.
    02-15-2018 04:33 PM
  3. JC8865's Avatar
    Ahhh yeah that makes sense,the one I was trying to install was from the Web. Thanks for the reply.
    02-15-2018 10:33 PM
  4. Str0ntium's Avatar
    https://forum.xda-developers.com/sho...7&postcount=24
    I like the Helvetica Neue. Most of the fonts on the store won't work. Under lock screen and security, make sure "unknown sources" is toggled on to install the apk's.
    02-16-2018 06:37 AM
  5. Smply_Rckless's Avatar
    JC
    Check out wings for substratum. Has a ton of fonts & etc
    SpookDroid likes this.
    02-16-2018 07:24 AM
  1. How do I stop this shortcuts page from popping up on my android...
    Last Post: 02-15-2018, 06:10 PM
  2. How do i move data onto sd card that i installed onmy android 6.0.1
    Last Post: 02-15-2018, 05:35 PM
  3. installed callx on my Google pixel XL but the recordings have no sound
    By Android Central Question in forum Google Pixel & Pixel XL
    Last Post: 02-15-2018, 04:45 PM
  4. I can't install Upday News cards for Bixby
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 02-15-2018, 04:35 PM
  5. Massive WiFi usage from "Android OS"
    By Paul Sutton in forum Legacy Android & Other OS's
    Last Post: 02-15-2018, 03:24 PM
