Galaxy Note 10 Deal: BOGO at Verizon!
  1. palanilopez12's Avatar
    Battery went from 83 percent to 61 in a 6 and a half hour period while I was sleeping with no usage and I'm not showing any real difference in the phone being held awake. Please help!
    Attached Thumbnails Serious battery issue...please help-screenshot_20180226-010151.jpg   Serious battery issue...please help-screenshot_20180226-073645.jpg   Serious battery issue...please help-screenshot_20180226-074658.jpg
    02-26-2018 06:48 AM
  2. Morty2264's Avatar
    Looks like your screen is taking up some of the battery percentage. Is your screen on auto-brightness?
    02-26-2018 06:50 AM
  3. palanilopez12's Avatar
    It's on auto brightness. When going to sleep the phone used to drain, at the most, 5 percent overnight. But recently it's been over 20 percent through the night and that just isn't normal.
    I'm wondering if it has anything to do with the fact that a few weeks ago I was in Paris and was roaming internationally. I never had any problems until then.
    02-26-2018 07:48 AM
  4. Morty2264's Avatar
    How long have you had the phone?
    02-26-2018 12:42 PM
  5. palanilopez12's Avatar
    From release date
    02-26-2018 12:45 PM
  6. B. Diddy's Avatar
    Can you show us the cell signal strength during a battery drainage episode? If the signal isn't strong, that can eat up battery.
    Morty2264 likes this.
    02-26-2018 04:50 PM
  7. mcaspe1's Avatar
    disable bixby.
    03-03-2018 12:06 PM
  8. Dooki's Avatar
    disable bixby.
    Bixby uses almost no battery.
    03-03-2018 12:25 PM
  9. wunderbar's Avatar
    do you use the facebook app? I used to have this problem where my phone would randomly drain 40%+ overnight. I disabled the facebook app and it hasn't happened once since.
    03-03-2018 10:52 PM
  1. AOD issues - no stock text showing up
    By Fwafwow in forum Samsung Galaxy Note 8
    Last Post: 02-26-2018, 07:34 AM
  2. Replies: 1
    Last Post: 02-26-2018, 06:59 AM
  3. Help me out with this question. Please?
    Last Post: 02-26-2018, 03:27 AM
  4. How to root alcatel onetouch pixi 3 10 3G tablet android version 5.1 help?
    By Android Central Question in forum Alcatel Android Phones
    Last Post: 02-25-2018, 10:46 PM
  5. How to root alcatel onetouch pixi 3 10 3G tablet android version 5.1 help?
