Waze hangs when using Whatsapp or Hangouts call
So several weeks ago I noticed that if I'm using Waze, and then take a call from Whatsapp or Hangouts, my Waze application stops working altogether. Also, after it crashes, I need to reboot my phone most of the time to get it to work again, even if I've hung up on my Whatsapp or hangouts call.
Worked fine up until I'd say maybe 6-8 weeks ago if I had to guess, not sure the exact time frame just know it worked fine until recently.
Have checked to see if it was in battery saving mode or something along those lines but doesn't appear to be.
Anyone else experiencing this issue as it's driving me nuts!
Re: Waze hangs when using Whatsapp or Hangouts call
Same happens to me when using WhatsApp. I don't use Hangouts, so I can't comment on that. I would say is not an S8 issue, as I have recently switched from S6 and same was happening on that one. I think it started a couple of months ago for me as well. Have you found any answers? Thanks
