    Hi all,
    I have e Samsung Galaxy S8 and since a few days the network connection is lost on this device and I see an "disables" icon on the top of the screen. Wifi and Bluetooth works, it is only the cellular network that has issues.
    Already checked with the operator and the SIM is fine, it works on an other phone. Also tried a different SIM card. I also tried to do a factory reset, no luck. Airplane mode on-off, all these things have been tested. ... . I didn't found a similar problem on the internet.
    Please let me know if there is anything else I can test.
    Best regards,
    Sam Berckmans
    03-07-2018 07:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! If it also happens in Safe Mode, then the SIM reader itself is probably faulty. Contact Samsung for warranty repair. https://support.t-mobile.com/docs/DOC-34283
    badcat likes this.
    03-07-2018 10:16 AM
  3. tube517's Avatar
    Try resetting network settings. It may erase your wifi passwords and saved wifi locations/passwords but give it a try.
    https://support.t-mobile.com/docs/DOC-34251#steps3
    03-07-2018 10:40 AM
  4. Dawn Kirkland's Avatar
    Hi all,
    Best regards,
    Sam Berckmans
    08-27-2018 05:00 AM
  5. Dawn Kirkland's Avatar
    Hi. I have the same problem. Did you manage to get it fixed?
    08-27-2018 05:00 AM
  6. Thomas Fant's Avatar
    Hey, so if you're still having this problem, check to see if you have wi-fi calling enabled. If so, turn it off, turn off your phone's wi-fi, and restart your phone. My network came back after doing that, I was minutes away from doing a factory reset, so hope that this tip can help you
    *Edit: Forgot to note, It's under Settings: Connections: Wi-Fi Calling
    09-01-2018 06:47 PM
  1. Why screen unlock is so difficult in S8 plus?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-26-2018, 02:15 PM
  2. How do i turn on the url in my phone to connect with my pc
    Last Post: 03-07-2018, 11:42 AM
  3. How do I change default video player on s8 Plus ?
    Last Post: 03-07-2018, 10:21 AM
  4. Does the S8 have iR - Infra Red so it can be used as remote control?
    Last Post: 03-07-2018, 04:52 AM
  5. How to connect my Samsung Galaxy Note 10.1 2012 ed. to Canon 7d?
    Last Post: 03-06-2018, 11:40 PM
