1. xxx JeNeSaisQuoi xxx's Avatar
    I just had to switch from one S8+ to another S8+ (broke screen). I installed my previously purchased package disabler Pro (along with that weird engine plugin they once added), but now it doesn't disable anything. It wanted me to download some other plugin, which I did, but it didn't change anything and keeps asking me to do the same thing... The app has ALWAYS worked flawlessly on the S8+ I just switched from... Any suggestions?
    03-12-2018 11:30 AM
  2. Tim1954's Avatar
    Perhaps uninstall and reinstall the app..
    03-12-2018 11:58 AM
  3. xxx JeNeSaisQuoi xxx's Avatar
    Tim: I have; a number of times... 😞
    03-12-2018 12:13 PM
  4. al3azim's Avatar
    I believe the older version of package disabler Pro no longer works and it was removed from the play store. The developers created a newer version. If you have a copy of your Google receipt showing the original purchase, email the developer with that receipt and they will send you an unlock code to download the new one which should hopefully fix your issues.
    03-12-2018 12:58 PM
  5. DsM's Avatar
    I'm assuming you're sideloading from the developer's site. The Playstore version is worthless.
    03-12-2018 01:09 PM
  6. xxx JeNeSaisQuoi xxx's Avatar
    al3azim: I wrote to them yesterday, but I haven't checked my email to see if they wrote me back yet. It's a good idea though; I hope that it will work...
    DsM: yeah, Google store has several and none of them I would even bother downloading. It was from developer site, but for some reason it just wouldn't open... I mean it would open and close or glitch... I tried to use the APK file from my old phone, but, to my greatest disappointment, it didn't work. Takes me through the same path, unfortunately...
    03-12-2018 07:43 PM
  7. filanto's Avatar
    I gave up on getting the new app for the old one that was removed, I just bought the newer one without the add-on app. works fine. the back and forth with the developer cost me more hassle than just buying the new one 🤗
    anon(123856) likes this.
    03-12-2018 09:10 PM
  8. filanto's Avatar
    03-12-2018 09:11 PM
  9. filanto's Avatar
    this is the new app
    03-12-2018 09:11 PM
  10. SL2's Avatar
    What about BK Disabler, does it work?
    03-13-2018 07:13 PM
  1. Replies: 6
    Last Post: 01-12-2019, 09:37 AM
  2. Samsung s8 and mirrorlink
    Last Post: 05-05-2018, 01:14 PM
  3. The time on mylock screen is wrong. How to I change it?
    Last Post: 03-12-2018, 07:16 PM
  4. How to I adjust my volume on my galaxy S8+
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-12-2018, 04:08 PM
  5. How do I get rid of LG TV remote on Note 4 phone
    By Bernice Stewart in forum Samsung Galaxy Note 4
    Last Post: 03-12-2018, 12:49 PM
