A
Android Central Question
Hello,
I'm still having a problem with my drain rate for 3 months now.
I have tried to disable apps and settings in many combinations, but the drain rate doesn't seem to be affected much.
The variables are AOD, WiFi, different WiFi routers, 4G, 3G, safe mode, airplane mode, two SIM cards from the same provider, two different SD cards different speed rate. Combinations of these variables always give drain rate of more than 2% per hour. All tests were done in standby mode.
Example of the tests I ran:
sd sim wifi 4g airplane drain
- - - - - 0.1
- v - v - 2.3
- v - v - 2.6
- v - - - 2
- v v - - 2.8
- - v - - 2.8
v - v - - 2.2
My last test was to pull out both SIM and SD cards, WiFi off, AOD off. High accuracy for location. Not in safe mode. Not in airplane mode. Overnight it drains at 0.1% per hour. I concluded the phone is physically free of defects.
Please notice the screenshot of GSAM chart. What is that active signal that keeps going on in the background? The only way to stop it is to pull both cards and disable WiFi, and the drain rate downed to 0.1% per hour.
Samsung service center suggested me to try airplane mode and safe mode, but both tests failed at drain rate between 2% - 3%+ per hour.
What could possibly have I missed?
- - - - - 0.1
- v - v - 2.3
- v - v - 2.6
- v - - - 2
- v v - - 2.8
- - v - - 2.8
v - v - - 2.2
