1. kotegpenz's Avatar
    Hi!
    So I have my S8 for two weeks now and I noticed something annoying yesterday.
    There are some grey dots on the top of the lock screen and it is not part of the wallpaper.
    On the home screen I have some weird stripes which are moving when I scroll to see the apps.
    https://photos.app.goo.gl/hDVbOH5kr5XnnwcC3
    https://photos.app.goo.gl/7sohjPWTqhNqWOME2
    03-23-2018 02:28 PM
  2. Tim1954's Avatar
    Dial *#0*#, that will get you the service menu.
    Check the screen hardware there. If it passes, it's software, if not, it's hardware (screen).
    03-23-2018 09:26 PM
  3. kotegpenz's Avatar
    03-24-2018 04:23 AM
  4. kotegpenz's Avatar
    03-24-2018 04:24 AM
  5. mary beth hale's Avatar
    Do the colors and the touch.
    03-24-2018 10:27 AM
  6. kotegpenz's Avatar
    I tried them. Everything seems to be ok.
    Is it possible that the theme has bugs? Because if I change it the problem disappears.
    03-24-2018 10:41 AM
  7. jeffmd's Avatar
    man those are some bad pictures... there is NOTHING in the first one and the second could very well be compression artifacts.
    Dots do usually signify a menu of some sort. If you either tap the area or thumb it down does an app window scroll in?
    03-24-2018 12:29 PM
  8. kotegpenz's Avatar
    I think I was just overthinking it. Other wallpapers are working good.
    03-27-2018 12:00 PM
  1. Galaxy S7 Edge wifi upload issue
    By ungairis in forum Samsung Galaxy S7 edge
    Last Post: 03-24-2018, 07:18 AM
  2. What is going on with my Galaxy S8's screen?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-23-2018, 02:21 PM
  3. What is going on with my Galaxy S8's screen?
    Last Post: 03-23-2018, 02:16 PM
  4. What is going on with my Galaxy S8's screen?
    By Android Central Question in forum Lenovo Tab S8
  5. Quick launch camera featurenot working on Galaxy S9 Plus
    Last Post: 03-23-2018, 01:26 PM
