    I've had my Galaxy S8 since around July 2017 and have only had one issue with it not turning on, but that was easily solvable. Anyway, on to my issue.
    It started 2 days ago. Whenever I play audio with Google Play Music through my AUX earbuds, it stutters (it sounds like someone is pressing play+pause very fast). However, it only does this when the screen hasn't been doing anything for sometime, or when the screen is off. It works perfectly fine if I'm typing or doing something on the screen, or if I don't have earbuds in.
    I know it isn't an issue with the earbuds since they work fine on other devices, such as my 3Ds. I think it's an issue with my actual headphone jack.
    Any ideas on how to fix this would be appreciated
    Kalo187 likes this.
    03-29-2018 09:13 PM
  2. Rukbat's Avatar
    If it's an issue with the jack, the jack needs to be replaced. It's that simple. (A part that sells for 99 cents retail can't be repaired - it's not designed to be.)
    03-30-2018 12:45 PM
  3. bmorlock's Avatar
    I don't think it's the audio jack. If it was why would the screen being on fix the problem. Mine is doing the same exact thing. Not 100% sure but it seems it started after I updated to Oreo.
    Kalo187 likes this.
    04-17-2018 10:16 AM
  4. Kalo187's Avatar
    It's got nothing to do with the jack. It's only been happening since this last update. Wired headphones. Every kind of set. I'm in electronics and I have never heard a failed jack sound anything like this stuttering. It is clearly a update problem that is creating some kind time lag with the audio wave
    04-23-2018 08:01 PM
  5. Kalo187's Avatar
    Turn off the UHQ. I don't even notice anything with music. I've had it off all day and not one stuttering track.
    04-25-2018 06:38 PM
  6. jeffmd's Avatar
    You need to go to battery settings and tell it not to restrict the focus of your music player when the phone tries to sleep.
    04-26-2018 08:46 PM
  7. jaybird210's Avatar
    i tried the battery setting to exclude from monitoring, but still had the stuttering. turning off UHQ seemed to do the trick for me. then after turning it back on it was still fine. not sure what in the UHQ setting is different between nougat and oreo, but mine also started acting up only after it was updated to oreo.
    06-06-2018 09:11 AM
  1. Verizon Galaxy S8 White bar on the bottom of my screen when on lock screen
    By ChiefDog in forum Samsung Galaxy S8 & S8+
    Last Post: 08-18-2019, 12:37 PM
  2. Anyone record professional audio with a usb adapter with the tab s2?
    By Android Central Question in forum Samsung Galaxy Tab S2
    Last Post: 04-15-2018, 11:07 PM
  3. S8 how to disable "Complete action using" pop up
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-05-2018, 07:58 AM
  4. Replies: 0
    Last Post: 03-29-2018, 08:41 PM
  5. Whats app not showing on S8+ on ÀOD OR LOCK SCREEN
    Last Post: 03-29-2018, 06:00 PM
