1. leeland48's Avatar
    Ever since the update I have had problems with my S8 now I can't turn on sync in samsung cloud I got Auto sync turned on I have cleaned cache but can not turn it on appreciate any help
    04-03-2018 07:24 AM
  2. leeland48's Avatar
    Thanks for the response I figured out the problem I was not connected to the Wi-Fi the phone shows a symbol saying am but I'm not ? I loved my Galaxy S5 it had nice easy settings but this galaxy s8 commumicates by innuendo.
    04-03-2018 11:57 AM
  3. Rukbat's Avatar
    The symbol says that you're connected to a wifi router - you may have a limited connection, which means no internet. It can happen if there's something set up wrong in the router or the phone (like setting up a static IP in the phone).
    04-03-2018 02:49 PM
  4. leeland48's Avatar
    Thanks Rukbut all my fault now I have another problem the Bluetooth is playing up I got it to Sync to my car yesterday and today it says no Bluetooth found ? ever since the update it seams very Buggy.
    04-04-2018 04:06 AM
  1. Transferring photos from Pixel 1 to macbook problem
    By Coojiang in forum Google Pixel & Pixel XL
    Last Post: 04-04-2018, 12:22 PM
  2. Oppo google contacts/calendar doesn't sync, experiencing some problems
    Last Post: 04-03-2018, 02:18 AM
  3. Syncing in the Car
    Last Post: 04-02-2018, 09:35 PM
  4. sync phone to outlook
    Last Post: 04-02-2018, 05:12 PM
  5. MyMail problems.
    By IMANUT46 in forum Samsung Galaxy S5
    Last Post: 04-02-2018, 04:41 PM
