1. THEPRFCT10's Avatar
    Just like the title says I'm trying to figure it out if there's a way to keep the Wi-Fi turned on when I select airplane mode seems a bit strange when I turn on airplane mode it turns off my Wi-Fi
    04-08-2018 11:34 AM
  2. B. Diddy's Avatar
    That's been the behavior of the Airplane Mode toggle for as long as I can remember. When you turn it on, it automatically shuts off all radios (cell, wi-fi, and Bluetooth). You always have to manually turn wi-fi or Bluetooth back on while in Airplane Mode.
    Laura Knotek and pankaj981 like this.
    04-08-2018 12:12 PM
  3. Rukbat's Avatar
    Think about it - "airplane mode" means "be able to use a phone on a commercial airplane which, until recently, had no wifi onboard. So airplane mode turns off anything that might interfere with the plane's navigation system, including wifi. (You wouldn't want the plane to suddenly think that the ground under you was "straight" and it was flying "up", would you?) Now that planes are tested for wifi susceptibility, and only those not susceptible to interference at 2.4GHz or 5GHz (and all the subharmonics and nose associated with wifi) have wifi onboard. There are still planes (any plane that doesn't have onboard wifi) that haven't been tested (and probably never will be - it's a tremendously expensive process), so you should keep wifi off on those planes. One touch - airplane mode - does that.
    Some time in the future, when every new plane will be tested and any problems fixed before it comes off the assembly line (and that's one of the problems - every single plane has to be tested, not just one test for that model), so phones will change and wifi won't get turned off in airplane mode. (Bluetooth, being on the same band of frequencies as 2.4GHz wifi), probably won't either.
    So all airplane mode will be doing is turning off the phone (talk, text and mobile data), and that would be due to the fact that from 35,000 feet you're going to be hitting a lot of towers with the same strength, and the cellular system just can't handle that. (One day, there will me a microcell on planes, so you connect to that, and it communicates with the ground by some other means - then "airplane mode" will be named something else - like "radios on/off" - because using a cellphone at a blasting site (and some other situations) is always going to be dangerous.
    04-08-2018 03:29 PM
  4. THEPRFCT10's Avatar
    You sound like you know a lot about airplanes! Sooooo is there a setting to keep WiFi on when selecting airplane mode? Apple does....
    04-08-2018 03:35 PM
  5. anon(123856)'s Avatar
    Just turn WiFi back on after you enable Airplane mode.
    04-08-2018 03:38 PM
  6. THEPRFCT10's Avatar
    Dude I know I can do that but that wasn't my question.
    04-08-2018 04:40 PM
  7. KSDroid01's Avatar
    I'm puzzled as to why this is important? Pull down the control panel, tap airplane mode, tap wifi, exit. It can't take a half-second for that second tap...
    anon(123856) likes this.
    04-08-2018 05:52 PM
  8. anon(123856)'s Avatar
    Dude, sure sounded like it. You asked how to keep WiFi on when enabling Airplane mode.
    mary beth hale likes this.
    04-08-2018 05:54 PM
  9. B. Diddy's Avatar
    The answer is no. Perhaps the designers didn't feel this was necessary, but you can always give feedback to Google and/or Samsung to let them know you think it would be helpful or important.
    04-08-2018 06:17 PM
  10. THEPRFCT10's Avatar
    Guys my point was simply to see if there was a setting where turning on airplane mode only turns off mobile data but keeps the Wi-Fi on because most airplanes now have Wi-Fi when I enter airplane mode I would like to keep the Wi-Fi on and yes I can tap it to turn it back on but that wasn't my question
    some_random likes this.
    04-08-2018 11:00 PM
  11. anon(123856)'s Avatar
    It would have helped a lot if you had just asked this straight out. We would have all said "no".
    As it was we thought we were answering your original question as posed.
    04-09-2018 07:56 AM
  12. Mooncatt's Avatar
    The entire purpose of airplane mode is to disable all radios, which includes Wi-Fi as well. Right now, I'm guessing there just isn't much demand to want Wi-Fi left enabled. Yes, there is Wi-Fi on some planes but it's not universal nor does it always work well when it's there. The last round trip I took, only 1 of the 6 planes I was on had Wi-Fi, and I couldn't get it to connect. So for me, I am fine with airplane mode as it is.
    04-09-2018 09:02 AM
  13. THEPRFCT10's Avatar
    I'm surprised to hear all you guys arguing against it --most airplanes on most Airlines now are installing Wi-Fi if you've been on airplanes that don't have it they will eventually have Wi-Fi this is one item on Apple where I appreciate it because you can actually customize it so that when you turn on airplane mode it will either keep Wi-Fi on or turn it on if it was off
    04-09-2018 07:35 PM
  14. THEPRFCT10's Avatar
    I apologize I just can't think of a way to be more clear with my original Post and question
    04-09-2018 07:35 PM
  15. Mooncatt's Avatar
    I just got to thinking. This app is often promoted for doing custom tasks, so maybe take a look to see if you can configure it to trigger Wi-Fi when turning airplane mode on? I haven't personally used it, just heard a lot of praise for it. There's a fee trial link in the app description.
    https://play.google.com/store/apps/d...ndroid.taskerm
    04-09-2018 07:44 PM
  16. B. Diddy's Avatar
    Maybe it'll be a feature that Google (or a manufacturer) adds in the near future.
    THEPRFCT10 likes this.
    04-09-2018 08:38 PM
  17. THEPRFCT10's Avatar
    Cool thanks
    04-09-2018 11:47 PM
  18. anon(123856)'s Avatar
    Your post (#10) was far more clear as to what you were looking for. And I don't believe anyone is "arguing against it". Saying that you can't do something doesn't mean I'm against it.
    I'm just not seeing this as a huge issue though, just tap two icons instead of one. Yes Apple may allow this and perhaps Android will add this in the future.
    It seems to me tapping two icons instead of one seems like a quick and easy workaround.
    sweetypie31 likes this.
    04-10-2018 06:31 AM
  19. THEPRFCT10's Avatar
    Understood thanks.
    04-10-2018 07:39 AM
  20. anon(123856)'s Avatar
    Understood thanks.
    I hope it works out for you. Maybe Android will add this as an option in the near future.
    04-10-2018 07:41 AM
  21. B. Diddy's Avatar
    Oh look, here's a SUPER SIMPLE way to do it! Being sarcastic, of course.
    https://www.xda-developers.com/custo...-mode-android/
    mary beth hale and THEPRFCT10 like this.
    04-11-2018 08:50 PM
  22. THEPRFCT10's Avatar
    Lol yeah no thanks!
    04-11-2018 10:35 PM
  1. Numbersync issue on GalXy S9+ & smartwatch
    By jgreg02 in forum General Carrier Discussion
    Last Post: 06-06-2018, 10:30 PM
  2. S9+ on Sprint
    By kdmea in forum Samsung Galaxy S9 & S9+
    Last Post: 04-09-2018, 06:00 PM
  3. Wifi Connection or Data Plan
    Last Post: 04-08-2018, 07:46 PM
  4. Need to active contact caller id on my huawei nova 2i
    Last Post: 04-08-2018, 03:32 PM
  5. How do I undo an preinstalled app update on my samsung phone?
    Last Post: 04-08-2018, 03:10 PM
